Everytime I try to remove my 2GB card from card reader(#SDDR-89) I get a warning that I have done it incorrectly. I have followed directions, but it is not working properly. I have an iMAC computer. Thanks for any assistence.
  • 3,051 Answers
Have you shut it down before you disconnected it
Posted on Aug 17, 2008
SOURCE:
Everytime i try to download music to my memory
try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Sandisk is not being recognized on my computer
SOLUTION 1 - Verify if minimum system requirement is met.
SanDisk card readers support Windows Vista, Windows XP SP2 and Windows 2000 SP4.
For MAC users, see
Troubleshooting USB device on MAC
SOLUTION 2 - Verify the reader's status under Device Manager.
STEP 1 - Connect the reader to the PC
NOTE: It is recommended that you plug your card reader to the back USB port on your PC to ensure that there is enough power from the USB port for the card reader to be detected properly.
STEP 2 - Check under Device Manager
1. Right-click My Computer.
2. Select Manage.
3. On the left pane, click Device Manager.
NOTE: The card reader will appear in two places: Disk Drives and Universal Serial Bus controls as USB Mass Storage. If there is a yellow exclamation point (!) or question mark (?) next to the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action, and then click Scan for hardware changes.
STEP 4 - Verify if the reader is detected
1. Double-click My Computer.
2. Look for the card reader under Devices with removable storage.
SOLUTION 3 - Try other USB ports.
A yellow exclamation point (!) under Device Manager usually means that the device is not receiving enough power. If the reader is not receiving ample amount of power from the USB port, it may not function properly.
SOLUTION 4 - Change the drive letters
NOTE: The SDDR-89 reader should show 4 drive letters under My Computer.
Mar 01, 2010 | SanDisk Sansa m250 MP3 Player
Format 32mb smartmedia in FAT12
Hi friend,
ok you can try to format on windows xp.
Follow these steps:
1.Open Control panel
2.Open administrative tools
3.open computer management
4.then click disk management
select the drive and try to format as per you requirements . note that you can also delete the partition and create new..
ok
Regards
Uttam
Jan 13, 2010 | SanDisk 2GB microSD Memory Card
Write protection
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!
Jul 18, 2009 | PNY 2GB microSD Memory Card
Memory card cant be read My 4gb SanDisk microSD memory doesn't read on my computer. I bought it today at Radio Shack.
Are you using a card reader? If yes, you need to isolate the problem. Please follow the steps below:
1. Try connecting your memory card reader into different USB port of the computer.
2. Try using different card reader to see if there's a problem with the card or with the reader.
3. Connect it into different computer.
4. Remove and reinsert the MicroSD in the card reader and make sure that the card is properly seated.
5. If the card reader and the computer are working but still unable to detect the MicroSD, try to reformat the card.
6. If same problem persist, return it to the store and have it replaced.
Have a great day!
May 26, 2009 | SanDisk 2GB microSD Memory Card
HP Pavilion ZD8000 Digital Media Reader Issue
Try updating you drivers for your digital media reader. Also check your dcos to see if the DMR will read a 2GB card
Jan 11, 2009 | HP Pavilion zd8000 Notebook
WINDOWS VISTA WILL NOT ACCEPT INSTALLATION PROGRAM FOR SANDISK CARD READER MODEL SDDR-89.
go to sandisk website and get window wista driver for it
install it and use it
Jun 02, 2008 | Computers & Internet
SDDR-113 card reader reading very slow and only loading 1 photo
Dane elec 4gb card not compatable with reader
Apr 11, 2008 | Cameras
Computer just won't recognize reader
Was referring to the configuration. P3, P4, etc. Older boards that have a USB 1.1 port sometimes have compatibility issues with some USB 2.0 devices.
I recommend trying it on other XP-based computers. If it still doesn't work then the device has a problem. If it works then it could be a compatibility issue with your PC.
Hope this helps.
Jan 26, 2008 | SanDisk MobileMate SD Plus 5-in-1 Media...
Open Questions:
Computers & Internet Logo
44 people viewed this question
Ekse
Alun Cox
