Have you tried to manually light the burners with a lighter? If so and you can not light the burners then you have 1 of 3 things that usually happen. First and forth most you have a blockage in the lines. You should be able to hear gas going throught the line and out of the vent. If you couldnt light the burners manually then this is probally the issue. Check your lines and connections at the bottom of the burners. The second thing could be that is your tank is just to low or empty. I have left the burners on and ran through my gas with out knowing it so check the tank. The last thing it might be is the regulator is broken. After checking the lines for blockage you have to check the gas regulator on your hose and the tank. If it is this problem let me know after you get through the rewst of the checks.
Thanks
Mike
