Question about Intel Computers & Internet
Motherboard biose updated data
M.b type p2
modal no fw82443lx
  • 594 Answers
The only thing i can get for you is the chipset software installation utiliy. if this will help you let me know.
Posted on Aug 17, 2008
Problem with COMPAQ DC5850 SFF ATH/5000 2GB80GB COMBO WVXP PC Desktop hp compaq dc5850 pc won't turn on after plugging in old hard drive for transfer Posted by Author imageGuest on 1/4/2013
The h3ll you say.
(Kidding around)
Let me see if I understand this straight;
You unplugged THE harddrive to your computer..............
Then you plugged an old harddrive in, and expected to be able to use it.
Expected to because you've done it in the past.
1) Was it an old harddrive you had in the computer, removed it; and had a larger one installed?
2) Is it one that you have had in another computer?
Here's what I know, and why I'm asking;
When Windows is installed on a computer it assigns hash values, to certain major hardware components.
For example;
A) Processor
B) Motherboard: To include the motherboard chipset, and BIOS program. (To include version and date)
C) Harddrive
D) Graphics chipset
Change any two of these hardware components, and Windows will think it is being stolen. Put on another computer.
Microsoft User's License states, "One GENUINE copy of Windows per ONE computer"
(Microsoft makes one Master disk, and from it all GENUINE copies are made, and sold to the consumer)
Now if you stated you installed the old harddrive as a Slave drive; then I could understand.
P2 connector?
That is a Power Supply power cable.
According to specifications the Harddrive is a SATA unit.
Internal Drives - Hard disk controller -SATA 3.0Gb/s NCQ SMART IV
The power cable to it is a SATA power cable,
Probably what your P2, and P3 power cables are.
P1 will be a 24-pin ATX main power cable,
P4 cable,
P5 cable, MAYBE, (Might be P3 too)
And P6 power cable,
This type of power cable is also used on a Card Reader.
To conclude;
A) SATA harddrive has to have a SATA power cable, and SATA data cable.
The SATA power cable's connector is wider, than the SATA data cable's connector.
15-pins for the SATA power cable connector; 7-pins for the SATA data cable's connector,
The above is a general example of a SATA data cable, and it's respective connector on the motherboard.
Your SATA data cable connectors on the motherboard, are of a different style than the above.
You have Four SATA connectors on the motherboard;
1) Light Blue
2) Orange
3) Dark Blue
4) White
Jan 04, 2013 | HP COMPAQ DC5850 SFF ATH/5000 2GB80GB...
Mother board power is on then shut down 15 to solve this problem.
first : check the biose of the board ,try to updat the biose .
2nd: check the ram fixed in board if its ok then check the bus
of the ram & board bus
3d: finally check if cpu work corroctly by replacing cpu .
Sep 18, 2010 | Gigabyte GA-K8VM800M Motherboard
This program is unable to continue .the system you are trying to update does not support intel(r) express biose update or there are incompatible application running . pleade close all open application and...
Updating your bios is to risky it can ruin your your motherboard if you have mistaken to update your motherboard. Try to check your board has a newer version bios before you update it read also the how to update your bios and the problems you may encounter
Aug 08, 2010 | Intel D945GTP Motherboard
I have no sound and no driver
You need to update or reinstall the driver for the sound card.Your computer manufacturer support and drivers will have your driver for the sound card if its OEM with your computer. Just enter your computer modal number operating system find the right driver and install as instructed. If you have a problem let me know make and modal of computer and sound card if not OEM. and I will try to find the driver. Please rate me mysleuth
link for free drivers you have to sign up.
Mar 26, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Add Memory In Compaq Deskpro 6000 P2 Shuttle PC?
Before you get to that you may want to see what type of memory and much you can upgrade you shuttle. Go to and do a scan to see what memory you have in the system and if it worth upgrading. Then go to hp website and get the manual to find the motherboard.
Please rate, Thanks.
Feb 17, 2009 | Compaq (296671-001) for DeskPro 6000 P2...
Bios update problem
ther is a swich in your computer that tells it if system was opened its just a worning
go into your biose and turn warnings off,
its that simple.
i dont know you biose but i do know this proble.
and also make shure you close up your computer properly so it reds closed in the biose.
hope this helpsa,
Dec 29, 2008 | ASUS A7V400-MX Motherboard
Samsung P2 - partial unbrick
go to and download the firmware for the yp-p2LAB witht hat it will update images and everything else
Oct 26, 2008 | Samsung Yepp YP-P2 Digital Media Player
Can't boot bios
This is common after doing a BIOS upgrade. It usually means that the bios was successful, but that the motherboard is just now recognizing that it has a new bios. In other words, it's seeing that the new bios is not the same as the old one you had before, and is giving you a warning that it's changed. You can usually go into the bios, and clear all messages. This should make it go away.
Post your specific motherboard, and i'll see if I can get you more info.
Sep 16, 2008 | ASUS AMD 760 MP Chipset A7M266-D...
Motherboard doesn't accept WD 40 gig on.
When you say "the system didn't work with that", do you mean it didn't identify the drive? When you go into the BIOS setup, are the drives displayed, or are they shown as "Auto"? Did you correctly change the WD drives jumper to Master, and the old drive, to Slave?
May 25, 2008 | MSI Slot 1 MS-6119 Motherboard
Processor up grade
The fastest cpu you can use on your mb is a pentium 3 800. Providing that you have the latest bios update.
check this link here.
You may need to download and install bios update from factory website .
Feb 22, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Computers & Internet Logo
111 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
