Cannot type any letter after reformatting!
I had to reformat my windows xp and now i am facing many problems, the main one is that I cannot type any letter. i am using another pc now to search for a solution on the internet. the keyboard doesnt seem to be the problem as the troubleshooter stated that it is running properly. Could you help me solve this issue?
Thanks!
Please note my other key board is working (non wireless)
Posted on Aug 18, 2008
I cannot reformat my flash drive..always indicating" write protected" what shall i do to through reformat it?
Hi sampagac ,
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Hope this helps ...:) your feedback would be appreciated.
May 13, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My operating system was damaged by virus,i need ro reformat my computer..how can i reformat my competer?
Install the XP discs and restart the machine. It should boot from the discs. Then follow the onscreen instructions. You will want to reformat your main drive. (C:)
Apr 04, 2011 | Microsoft Windows XP Home Edition Service...
I cant access and format my pendrive even though nothing show in pendrive but when i go in properties option then pendrive memory show full please give me solution of this problem
Go to your Desktop. Right-click on My Computer and select Manage. On the left-hand pane there should be an option for Disk Management under "Storage". Click that. Look for your drive. You can usually recognize it by it's size.
There are several things you can do from there. You can reformat it, and assign it a drive letter. Or maybe it may need to just initialize. Usually you can play around in there and get it to work.
If it does not come up, chances are that either 1: Flash drive is bad or 2: USB port(s) is not working.
Apr 01, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My pendrive cant formate if i go for delet it shows specific path is not there
  • 1.Plug your flash drive into your computer's USB port.
  • 2.Click "My Computer" on the desktop to find out the letter of the drive you wish to reformat. For a flash drive, it should be removable disk F:, but check to make sure.
  • 3.Navigate to "Start," then "Run."
  • 4.In the Run window, type "cmd," which will bring up your MS-DOS window.
  • 5.In the MS-DOS window, type "Format F:/fs:FAT32." If your drive is designated with another letter, replace F: with that letter. Change FAT32 to NTFS if reformatting a drive larger than 10GB.
  • 6.Hit "Enter" three times, and you will have reformatted your drive
  • hope this helps you a little:
    pls rate............
    Feb 10, 2011 | Computers & Internet
    How to reformat window xp
    Reformat the Hard Drive in Windows XP
    1. To reformat a hard drive with Windows XP, insert Windows CD and restart your computer.
    2. Your computer should automatically boot from the CD to the Windows Setup Main Menu.(If not, press F2 or DEL and choose first boot device CD or DVD)
    3. At the Welcome to Setup page, press ENTER.
    4. Press F8 to accept the Windows XP Licensing Agreement.
    5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
    6. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
    7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
    8. Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
    9. You have now sucessfully reformatted the hard drive with Windows XP.
    Jan 02, 2011 | Microsoft Windows XP Professional
    I want to fomat jetflash v30 in dos.so, please give me the steps for format
    1)Plug your flash drive into your computer's USB port.
    2)
    3)
    Navigate to "Start," then "Run." 4)In the Run window, type "cmd," which will bring up your MS-DOS window.5)n the MS-DOS window, type "Format F:/fs:FAT32." If your drive is designated with another letter, replace F: with that letter. Change FAT32 to NTFS if reformatting a drive larger than 10GB.
    6)
    Hit "Enter" three times, and you will have reformatted your drive.
    Nov 14, 2010 | Computers & Internet
    How to reformat the windows xp to my pc
    to boot from cd press F11
    Then press enter
    Jun 23, 2010 | Microsoft Windows XP Professional With...
    After booting pc it popup and gives errorlike
    goto start/run and type msconfig and nagivate to start-up tab , then select enable all or disable the one which has shooter.exe , apply and restart. your problem will be solved...
    Jul 04, 2009 | Microsoft Windows XP Professional With...
    REFORMATTING HARD DRIVE
    can u expalin your problem
    Jul 09, 2008 | Compaq Computers & Internet
    Trying to start from scratch
    Hi Use the following steps to open a command prompt environment and also make sure tht the OS disk is in the drive:
    1. Turn on the PC and press the F8 key repeatedly when the first screen appears. The Windows advanced options menu appears.
    2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
    3. Select Microsoft Windows Recovery Console .
    4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
    5. At the command prompt, type the following: diskpart
    6. Press Enter , do one the following:
      • If a table of volume names appears, remember the drive letter next to the main drive volume name and press the Esc key.
      • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name , type exit when done, and then press Enter
    7. Use the following steps to replace the boot.ini file with the backup boot.ini file:
      1. Type the following at the command prompt: X: (where X is the drive letter).
      2. At the prompt, type the following: ren boot.ini boot.in2
      3. Press Enter
      4. At the prompt, type the following: ren boot.bak boot.ini
      5. Press Enter
      6. At the prompt, type the following: exit
      7. Press Enter The system automatically restarts. If Windows XP does not open, continue to the next Step.
      If the above steps doesnt work then you will have to reinstall OS with the disks.
    Feb 13, 2008 | Toshiba Satellite A105 Notebook
    Computers & Internet Logo
    272 people viewed this question
    David Payne
    David Payne
