Question about Sony PS-LX250 Turntable
I am trying to hook together a computer and a turntable(Turntable has its own pre-amp) & I need a diagram on what wire gos where?
Turntable to a computer. I need to know where what wire goes where. The turntable has its own pre-amp.
Gene(gemcquaid)
[email protected]
    Problem Solver:
  • 7 Answers
OK. Since there is a pre-amp, all you need to do is to connect pre-amp output to Line-in input on the PC. This may be a bit of challenge as the connector on the pre-amp and computer are of different types. Usually, you need a cable with RCA connectors on one end and 3.5mm stereo pin (same pin as you have for stereo headphones) on the other.
Posted on Aug 22, 2008
SOURCE:
My Dual CS 430 turntable suddenly stopped playing - rest of equipment (radio, CD player, tape deck) okay. Can you help, please?
Amplifiers always take the sound of the turntable via a separate pre-amp from all other systems, such as radio and CD players. This pre-amp can go faulty killing the sound from the turntable only. If the turntable goes through the actions of playing the record, then this is the cause of your trouble.
Sep 20, 2016 | Audio Players & Recorders
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
I don't have a grounding wire and don't know what to use!
You can attach a wire to the metal part of the turntable and screw the other end to ground screw on the amp.
Mar 05, 2012 | Philips gemini XL-500 II Turntable
Cannot hook up sound to surround sound , everything else works, cd player, radio, tapedeck. just the turntable does not work. any suggestions? deb
Hi, you need to connect the turntable to your amp via a phono input connection. If no phono input available then a pre amp needs to be used between turntable and amp to up the signal. Cheers John. [email protected]
Sep 28, 2011 | Technics SL-1200MK2 Turntable
Can I connect a turntable to my Sony mhc nx3av system which I got 12/13 years ago and it is great. Will it be accessed via the MD option? And must I get a turntable with a pre-amp? Thanks in...
YES, you can not only connect a turntable but also a VCR or DVD player or other analog audio sources using either of the top two RCA INPUT jacks on your unit. Now, for a turntable, you will need to buy a pre-amp because typically a turntable provides too low a signal level for most components to handle. These pre-amps cost $35 and up. Most turntables do not provide a pre-amp. Usually an amplifier or receiver will contain the pre-amp and have PHONO inputs specifically for a turntable. So you are correct, you need a pre-amp of some kind. Be sure to select the inputs on your Sony where you connected the turntable when you want to play records. Hope this helps.
Mar 14, 2011 | Audio Players & Recorders
I have a Pioneer PL-202AZ turntable. I have to be able to plug it into my stereo receiver which is a Sony model # STR-DE635. What kind of adapter do I need? Any suggestions on where to purchase the...
I assume you mean the sony dosen't have a phono input? Then all you need is a Magnetic Cartridge Pre-amp. Your turntable plugs into this and the pre-amp goes into a spare aux on the Sony. Just do a search for the Pre-amp on google by putting in "Magnetic Cartridge Pre-amp".
Sep 19, 2010 | Pioneer Audio Players & Recorders
Hooking a turntable with it's own pre amp to a computer and/or a home theather system gemcquaid [email protected] .
Check your inbox.
Hook the output to Aux. As for your PC, that would depend on your sound card. Basically, the same.
Mar 01, 2010 | Sony PS-LX250 Turntable
Low volume on PS LX250h
This turntable has a built in pre-amp, under the platter is a on-off switch. Turn it to "on".
-Former PS-LX250H owner
Dec 12, 2008 | Sony PS-LX250H Turntable
Volume
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Aug 24, 2008 | Technics SL-1200MK2 Turntable
Sony PS-LX250 Turntable Logo
342 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
