Question about Onkyo TX-SV535 Receiver
Rear speakers dont work
I plug in all my speakers and its not only me rear but my center speakers dont work either is it just because its old? Does it have a loose cord? Pls help
  • ltleon Aug 17, 2008
    Because it is almost 20 years old but when i plug the front into the rear and turn it up really high you cant here that crackling sound like when you have it in the Main so i think it could be that its not getting power or a wire is disconnected
    Genius:
  • 1,074 Answers
Check all your speaker wires probably they are broken.if they check good then you will have to get a tech to look at your set it could be your set output ic or transistor gone bad and need to be replaced.and if it is a old set buy a new one probably it wont worth the while to repair it.
good luck
Posted on Aug 17, 2008
Need the speaker diagram wiring for a 97 chevy tahoe
1997 Chevrolet Tahoe Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size:
6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 01, 2018 | Car Audio & Video
I have a sony STR-DE897 and my rear speakers dont get sound when plugged into the surround back ports..Is there a certain setting in order for the rear surround spreakers to work? or does that mean the...
There are a few things required for the rear surround channels to operate;
1. The surround back channels must be enabled in the surround setup menu.
2. The media being played through the receiver must have audio encoded for the rear surround
channels. There are only a few exceptions to this but I'll exclude the explanation for simplicity.
3. The audio level of the speaker channels must be set high enough to be audible.
Enter the surround setup menu with your remote. Use the center button on the remote to toggle through the selections, press down on it to enter the selection.
You will navigate to a selection in the surround setup menu that says "surround back" or S/B with a selectable yes or no indication. Press on the center button to enable them.
Media like DVD or Blu-ray that has 6.1 or 7.1 channel audio has separate, or often referred to as "discrete" or "matrixed" audio intended for playback through surround rear speakers, depending on the music or movie. If your media is encoded for 5.1, then there will be no audio sent to these speakers. However, with the different modes of on-board digital processing of this receiver you can still have audio through these speakers.
Last but not least is the actual playing level of these rear surround channels. They may simply be adjusted to quietly. Enter the setup menu with remote, choose "level" and navigate to the rear surround channels. You can adjust the level up or down in 1/2 dB level increments by toggling left or right with the center button. Each surround channel can and should be adjusted independently and equally.
Dec 14, 2010 | Sony STR-DE897 Receiver
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
My surround rear spks dont work
The rear speaker decoding has to be enabled for them to function, regardless of the media. Enter the speaker setup menu and choose "yes" for the rear surround speaker decoding.
Mar 10, 2009 | Sony STR-DA3000ES Receiver
Noise on rear speakers
yeah i used to have this problem too forever, untill i was playing around with them and figured out the problem. on your remote there is a shift function, while holding shift you need to turn up rear speakers also on the remote, i think its near 1 or 2 or somthing. just look for rear level, turn that up and make sure you have the proper audio setting and that should fix it.
Oct 17, 2006 | JVC MX-J800 CD Shelf System
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Rear left speaker not playing
If the speaker itself is working then the problem will most likely be the connection point where the speaker plugs into. If you dont know how to check for this problem, i dont really want to tell you just in case you hurt yourself. Take it to a shop and have it looked at by someone thats knows what there looking for.
Sep 06, 2006 | Logitech Z-540 Speaker
201 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
