Question about KitchenAid 24 in. KUDP02FR Built-in Dishwasher
Won't power up
I recently installed a new soap dispenser in my kitchenaid dishwasher. The old one didn't open correctly. When the new one was sent to me it didn't have a gasket that fit between the dispenser and the door panel. I called the part supplier and asked about a gasket and they assured me one wasn't neede. I tightened all of the screws and it seemed to fit and work just fine. Now two days later the dishwasher won't power up. I'm wondering if water could have worked it's way into the control board which is located in the door and fried it ? Any thoughts or maybe it's something else?
  • 725 Answers
The control board is above the dispenser so it is unlike the water would get up there... I would check the door switchs you may have a loose one... good luck
Posted on Aug 17, 2008
SOURCE:
Soap door opens during cycle, but soap does not dispense??
Hello Eric, thank you for your post!
I understand that the dispenser on your Frigidaire dishwasher opens but the soap is not dispensing into your dishwasher. How old is your dishwasher soap? If it is around a year old you may need to discard it and use a new soap. Also check to make sure when you stack dishes that they are not obstructing the arms from reaching the dispenser. Make sure your spray arms are clear of any debris that could block the distribution of water inside of your dishwasher. You may need to connect with a professional technician for proper repairs if these steps do not correct your issues. I hope this information is helpful to you. -Matt
Aug 02, 2015 | Frigidaire Dishwashers
Kitchenaid dishwasher soap dispenser will not open during cleaning cycle
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 24, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher starting to leave soap film on dishes. It is a 2 year old Kitchenaid. Cleaned filter, no changes in our soap or water.
First check the salt dispenser located at the bottom of the machine under the bottom rack,make sure it is full,then also check the rinse aid dispenser is full and adjusted correctly,in the rinse aid dispenser it will have numbers turn the dial to about number 2 this is average
Dec 30, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap does not dispense from cup.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Oct 07, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
Dishwasher soap door repair
Remove door front panel to gain access to rear of dispenser (inside door)...then you have access to some linkages to which the trigger clips. You will see which to unclip. Spring is just clipped into position and dispenser door snapped back in! Good luck! Oshie
May 31, 2007 | Gaggenau GI936-760 Dishwasher
KitchenAid 24 in. KUDP02FR Built-in Dishwasher Logo
130 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
