Question about HP Compaq Presario V2000 Notebook
Compaq Presaro V2000 will not power on after mini-pci card removed
I installed a Broadcom Mini-PCI wireless card (BCM4306) in my presario V2000. When I switched the laptop on I got an error message 104 saying remove new hardware and reboot.
I switched the laptop off and removed the mini-pci card. Now the laptop will not power on. No light comes on when the power adapter is connected to the laptop
  • 22 Answers
HELLO,PRESS AND HOLD THE POWER ON BUTTON FOR A FEW SECONDS UNTIL YOU GET A POWER LIGHT.ONCE YOU GET THE LIGHT,THE LAPTOP SHOULD BOOT UP NORMALLY.IF THAT DOESNT WORK,REMOVE THE BATTERY AND TRY TO POWER UP WITH JUST THE AC ADAPTER PLUGGED IN.ONCE YOU GET BOOTED,INSTALL THE BROADCOM WIRELESS CARD SOFTWARE FIRST FROM THE CD THAT CAME WITH THE ADAPTER.THE SET-UP WILL THEN ASK YOU TO INSTALL THE CARD AFTER THE DRIVERS HAVE BEEN LOADED.YOU SHOULD BE ABLE TO GET ONLINE ONCE ALL THE STEPS HAVE BEEN COMPLETED.GOOD LUCK
Posted on Aug 17, 2008
I have a g5690 shuttle and would like to install a wireless card to connect to our home wireless network. What shoeld I buy?
My suggestion would be a mini-pcie laptop card, N300 or higher (you can buy them on Amazon and Ebay for around 25 dollars, Azureware or Intel are usually good) and a low-profile mini-pcie to pcie adapter which comes with antenna. Azurewave AW CE123H 802 11ac nbg WiFi BT PCI Express Module Broadcom... Mini PCI to PCI Wireless Adapter 3 Antenna WiFi
Dec 26, 2014 | Shuttle Computers & Internet
Gateway 600yg2
I may not be understanding what you are stating, so bear with me;
1) The Wireless Modem antenna wires are up in the Display Assembly,
http://www.mundocorp.com/shopexd.asp?id=1160
In otherwords they should already be there.
2) The 802.11 Mini PCI Card, is a Wireless Module.
It goes in the Mini PCI Compartment, under the Mini PCI Compartment Cover, located on the bottom of the laptop.
It's made by Broadcom,
(Gateway 6002672 part number)
http://support.gateway.com/s/Mobile/NETWORK/Wireless/6002672/6002672mv.shtml
See at the Top right where it states Main, and has a white Side Arrow?
This terminal is where the Black wire (Lead) of the wireless antenna connects to.
The other terminal, AUX, is where the White wire connects to.
http://www.laptops-we-r.com/prestashop/gateway-6000-parts/418-gateway-dell-broadcom-bcm94306mp-b-g-mini-pci-wifi-card.html
Here is the Service Manual, (PDF file form),
http://support.gateway.com/s/Mobile/Gateway/600YG2/8508798.pdf
Page 13.
REMEMBER, remove ALL power. Remove the AC adapter (Charger), and Battery, before working on the laptop. Also follow Anti-Static Precautions.
Regards,
joecoolvette
Aug 20, 2012 | Gateway Computers & Internet
Error Message: 104-Unsupported wireless network device detected. System Halted. Remove device and restart.
I think you can try this steps and hope it will help you.
Try to reseat the Wireless Card in your machine.
You will need the following tools to complete the removal and replacement procedures:
-Magnetic screwdriver
-Phillips P0 screwdriver
-5.0-mm socket for system board screwlocks
-Flat-bladed screwdriver
-Tool kit-includes
Turn the machine upsidedown
Remove the battery.
Wireless Card Removal
1. Loosen the PM2.0×5.0 screw 1 that secures the Mini PCI
compartment cover to the computer.
2. Lift the rear edge of the Mini PCI compartment cover 2, and
then swing it forward.
3. Remove the Mini PCI compartment cover.
4. Disconnect the wireless antenna cables 1 from the Mini PCI
communications card.
5. Spread the two retaining tabs 2 that secure the Mini PCI
communications card to the communications compartment
socket. (The board rises up).
6. Remove the wireless communications card 3 by pulling the
board away from the socket at a 45-degree angle.
**Reverse the above procedure to install a Mini PCI
If happens that it does not work, I think you can just reinstall OS just to make sure if its Hardware or Software problem.
Thank you for choosing FixYa.
Apr 24, 2011 | HP Compaq Presario V2000 Notebook
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
Compaq presario 2100 how to install a Wireless pci card
If there is no antenna then you'll have to buy the wire set via eBay, take apart the lcd, remove the top assembly of the laptop and then run them through the computer and put everything back. NOT FUN.
It's probably much easier and realistic to just purchase a usb wireless card.
Hope this info helps.
Let me know if you have any other questions.
Best of luck!
--RescueTechLA
Nov 28, 2009 | Computers & Internet
Compaq presario 754tu & 765Tu Wireless driver
One of below links should work:
http://saysprasad.wordpress.com/2008/07/15/compaq-presario-c754tu-drivers-for-windows-xp/
http://www.zyxware.com/articles/2008/01/16/compaq-presario-c748tu-laptop-drivers-for-windows-xp
PLZ GIVE RATING BY CLICK YES OR NO.
Apr 28, 2008 | Broadcom BCM94306MP - IEEE 802.11b/g...
My wifi is not working
I do not know anything about my laptop so please help me taking I am a layman and dont know anything
Apr 11, 2008 | Broadcom BCM94306MP - IEEE 802.11b/g...
Download worked for detecting networks, but still problem
i use compaq presario v2388TU, ican't detect wireless adapter.
Mar 31, 2008 | Broadcom BCM94306MP - IEEE 802.11b/g...
HP Compaq Presario V2000 Notebook Logo
136 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
