Mitsubishi VS60609 problem
I have tried to hold down the menu and power button to try and get a code but It wont give me one. Every time I push the power button it acts like it is just getting ready to turn on then ... click from somewhere, and it goes off. I checked all the fuses, is there any thing else I can check? Thanks, Brian Sigourney gsxawd@kc.rr.com
  • jf098391 Nov 11, 2008
    Problem started with everything getting darker and darker until there was nothing but a balck screen but it had sound. I tried convergence, still nothing. I tried the picture in a picture (PIP), and I had a good picture there, but the full screen was black. Frusterated a couple days later I tried again, then I was having the problem of the unit trying to come on and then 5-10 seconds later powering down. After trying multiple times, I gave up. Can anyone direct me to the problem or the correct part I need so I don't have to have someone come out to service it.
    Thanks.
  • 8,617 Answers
Check the low Voltage regulators, and the horizontal out put transistor
Posted on Aug 17, 2008
I have locked my tv now power will not come on...mitsubishi vs60609
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "0", "1", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
NOTE: At this time channel 3 is automatically selected.
Select initial settings. Come to V-Chip lock option [6]. Here you can unlock the V-chip.
Oct 26, 2012 | Televison & Video
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Push power button and timer button lights for a few seconds and then tv turns off model is Ws 55859
When it shuts down go to the set and press the menu and the Device/Input button both in together and hold for 6 seconds then count the two digit blink code from the power indicator. it will blink a two digit code which repeats several times.
Jul 23, 2011 | Mitsubishi WS-55859 55" Rear Projection...
The tv wont power on and the green timer light continuously blinks. I have unplugged the the tv and also hit the reset button.
...OK to begin troubleshooting this. Unplug the set and leave for 1 min then plug up and leave for 2 min push the power button and let light blink for 2 min.... now push and hold at the same time the MENU and DEVICE buton st the same time. this is the self diagnoses feature ... the lights should link then pause then blink again... this 2 digit code will help narrow it down. Also have you check the lamp yet?
Oct 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
VS 5001R sounds like its gonna turn on but doesnt
This chassis model line had issues with the vertical output IC shorting causing shut down.
It also had issues with intermittent solder connections in the Horizontal Circuit. I would not try to fix it your self unless you are very familiar with Projection circuitry and electronics background.
Hope this helps,
Skyassoc
Jul 02, 2009 | Televison & Video
2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
Jun 03, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Powers on for three seconds then goes off
The first thing to do is to try to determine why the set is not turning on. It is equipped with a self diagnostic feature. On the front of the set push the MENU and DEVICE button at the same time and hold until the LED starts flashing a two sequence code. That will narrow things down for us.
Apr 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
WD-52327 Red Light Problem
Try pushing input and menu buttons in together on the front TV panel and hold in for 8 seconds to see if the set blinks a two digit code as it may have bad capacitors if it blinks a 3 4 code.
Jun 05, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi VS-70707 rear projection TV
Try pushing Input and Menu together and hold them both in for 5 seconds to see if it blinks a 2 digit code which repeats itself. Then let me know what it does and we can go from there.
Jan 12, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
