Pavilion a288n video loss
Tried working monitor, adding video card but still no video
  • bozzie Aug 17, 2008
    Thank you for your advise. I have no additional PC2700 DDR RAM other than the one stick the I placed in both slots; but I tried some standard DDR 333 with no luck (just a long there a difference?). I tried other electrical outlets and they had no effect. I am reluctant in spending $ on new PC 2700 for this system but I have had several RAM related problems over the years.
    I tried to use the on board video also with no luck. Do you have any other ideas? What about the power supply?
    I still have the option of getting the new PC2700 RAM and trying it out on the machine tomorrow.
  • 141 Answers
Check your memory. Memory is one absolute sign for no video. Also check the pins on the video plug to make sure none are bent or broken. You must make sure the pc is turned off when doing these things. And make sure your video card is seated all the way down. No gold showing outside of the pci slot. Also you can try another pci slot. Sometimes they fail. You can also try plugging your pc and monitor into another wall outlet. Believe it or not it is not uncommon that one wall socket will put out more power than another. I've seen it 1/2 doz. times myself in older houses.
If none of these suggestions work & you don't mind letting me know I could give a few more in depth possiblities to try.
Posted on Aug 17, 2008
  • Theresa  Smith
    Theresa Smith Aug 17, 2008
    You have to use the ram that your system supports.Get the same kind that worked before. You can ask first but I think your can return, at least for store credit if not cash, the ram if you need to.
    The on board video could be bad. You can do the same (returning) a video card if not the problem. Just don't let them talk you into one more than around $30.00 or you could go to comp. row: Miliam Dairy & N.W. 31st street by the airport. I just got a 64mg. video for $10.00 for a customer. You didn't say if you've tried a video card.
    It wouldn't be your power supply I'm pretty sure or else other devices wouldn't be running. I think unless you have ruled these two issues out you might be still in luck.
Hp pavilion 533w stuck in power saving what to do
The monitor is NOT receiving a video signal from the PC.
You could try a different monitor, but it is likely your graphics processing unit (GPU) has failed.
If your monitor plugs into the motherboard for the graphics signal, then you can purchase an 'ad-on' video card for your PC that will allow you to continue using that PC. Video cards come in a variety of shapes and sizes so you need to know what 'slots' for ad-on cards are available for use and how much your budget is. According to google, that model has onboard AGP graphics, so it will have PCI slots (do NOT confuse this with PCI-e they are NOT the same.) This is, (like the rest of your PC,) very old tech and there are sadly, not a lot of choices out there for PCI video cards. Basically, the ones left are the ones no one else wanted to are better-off calling local PC shops to see if they have any used cards for sale. You don't need anything more than a 32MB or 64MB card at the very most.
if you already have one, and are using it, then power everything down and unplug the power cord. Press the power the power-button for 5 seconds to ensure complete power-drain from the system. Completely remove the video card and blow-off any dust. Inspect the card for blown-capacitors, if none found; re-install the card, and reconnect everything and try it again.
Oct 21, 2014 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Black screen
If you know your monitor works then the likely culprit is the on-board video could be bad. If you can give me the model # of your computer or if it's a custom computer, the model # of your motherboard, I can let you know what kind of video card your computer takes and what brands to stay away from.
Good luck and hope this helps. If it does, please vote! Thanks!
Dec 01, 2013 | HP PAVILION M8200N PC Desktop
Hp pavilion 6648c no signal to monitor
Make sure the cable is in good on the back of the computer and on the monitor. If the cables are in good, then either the monitor is bad or the video card is bad. Try using another monitor on the computer. If the other monitor gets a No Signal then the Video Card is bad. If the other monitor shows a display and works, then the original monitor is bad.
May 01, 2012 | HP Pavilion 6648C PC Desktop
System will not turn on
If you are certian the pc is powered on, check the video card and any new card that has been added to the pc. If you have a video card installed, remove all other cards and retry your boot. If you still have no video, replace the card. If the video connection is on the board and you and have added a new video card, use the "old" connection to open your operating system and configure the video setting to use the new card and change connection.
Good Luck,
Jan 02, 2012 | HP Pavilion a350n PC Desktop
I have a hp pavilion a226n and no signal to the monitor I have replaced the cords and the monitor works on my other computer what do I need to do
Replace the Video Card after first making sure the card is fully seated in the Slot. If you added a different card to the expansion slot just below the video card move it to another slot.
Mar 20, 2011 | Computers & Internet
My hp pavilion a 1140n turn on fine but my monitor no display pc running good
Try using a different monitor to check if it is your monitor that is indeed bad.
Also, try using a different cable if possible.
If the computer is at fault (different monitor didn't work either) then you can try installing a graphics card.
Look inside your computer and see if a slot for a graphics card is there. This will be a single unique slot unliek the others in the system.
The video above shows how to choose and install a video card.
I recommend for purchasing
Feb 28, 2011 | HP Pavilion a1140n (PX774AA) PC Desktop
Monitor does not turn on. HP Pavilion f1903 Switch light just continues to blink
Reseat the connection of your video card from the motherboard.
If problem still continue, try using different video card on your motherboard and see if it works. If the display is OK then you will be needing to replace your video card permanently.
May 26, 2010 | HP Pavilion F1703 17" LCD Monitor
To my HP Pavilion Media Center A1430N, I lost ALL video signal
One quick thing to check is to see if your Video card is fully seated down in the motherboard? Sometimes they can pop up a bit, and you lose your output.
If that doesnt help, you could remove your memory, one stick at a time, to see if that helps. This could be the cause if you added memory from the old computer.
Oct 30, 2009 | HP Pavilion a1430n (ER900AA) PC Desktop
Fpd1975w display flashes on and off
what resolution are you setting your screen to? if you are setting it too high or to a resolution/frequency that your monitor doesn't support, it will do this. Try setting it to 800 x 600 w/ 32 bit color and a frequency of 60Hz. If you do this and the monitor still blinks, you may just have a bad DVI cable.
Jul 13, 2009 | Gateway FPD1975W 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
