Question about Philips HTS-6500/37 System
Speakers why does sound only come through the right speaker when listening to the t.v. but comes out of both when watching a dvd?
  • Philips Master
  • 5,568 Answers
The connection between the TV and the Philips for the left channel is missing or interupted.
There should be two connectors on each end, one red (right) one white (left).
If they are properly plugged in, then the left channel cable stretch is bad. These can be replaced inexpensively at any electronics store.
The sound when using the player is sent internally to the amplifier of the system; no cables.
Posted on Aug 28, 2008
2 Suggested Answers
  • 124 Answers
SOURCE: I have dvd home theater system. how can I listen
connect stereo rca jacks behind tv labelled audio out then connect to any available input in home theater receiver
Posted on Aug 30, 2009
When I watch tv, I get a squealing noise, but when I watch a dvd, I don't get the squealing through the surround sound, also when I listen to a dvd through the surround sound I don't get the s
R U getting 'feedback'?i.e. if the speakers on the TV and your external speakers are pushing the same 'sound' towards each other there could be feedback.
Oct 31, 2012 | Sony Televison & Video
I have had the Kenwood VR-407 since 2001. I also have a Mitsubishi projection TV, attached to the receiver. When watching regular cable TV (u-verse), I can not get sound from the rear speakers. I am using...
Most TV stations you watch don't send a surround sound mix so you won't get anything in the back speakers. DVDs generally all have a surround mix which is why it sends to all speakers. What you are experiencing is normal, Bob.
Jan 04, 2011 | Kenwood VR-407 Receiver
No sound
More than likely you need to go into your menu settings. Check to ensure that your TV speakers are enabled. The previous owners may had it hooked to theater system
Oct 20, 2009 | Toshiba TP50G60 50" Rear Projection...
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
Cannot get all speakers to work at once!!
It could be that every sound has its recording style, some record the sound to just left or right only(mono left or mono right) some has stereo, recorded on left and right. Some have induced additional sound that only surround sound is best at.
Or some base on signal strength, some cut or boost only to the level it is set to appear.
Apr 12, 2009 | Yamaha HTR-6030 Receiver
Scratchy sound from cd/dvd combo
sounds like the speakers are either damaged or have gotten water in them and damage the laptop speakers.
Mar 29, 2009 | HP Pavilion Media Center M1090n (PC100A)...
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
I can't hear people talking when i watch a movie?
I had the same problem and found that there was a connection problem with the center speaker. Do a sound check on all speakers and see if the sound is coming out of the center one. If not then just check you have connected it properly.
Jan 01, 2009 | RCA DRC220N DVD Player
Problem with Surround Sound when watching TV
No wonder you havent gotten no reply your listed under wrong tv
May 06, 2008 | RCA D52W19 52" Rear Projection Television
Surround sound from Sky +
Could be two things:
First you have to make sure the speakers are all active, there is a speaker button on the RXV361 front on the right I think but not on the remote, you need B setting for all speakers. You run the sound test from the set up menu.
or it could be that Sky is not showing the programme you are watching in 5.1 so you won't hear it from all speakers, you can force this by using the Music enhancer button of the RXV361 remote.
Hope that helps?
Sep 16, 2007 | Audio Players & Recorders
Philips HTS-6500/37 System Logo
76 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
