Question about Evenflo Jenny Lind Crib
How do I attach the fabric seat of my evenflow supersaucer? It was detached for washing and now I cannot figure out how to re-attach it. Fran. email:franblakely@yahoo.ca
  • 4 more comments
  • ejfan3 Jan 14, 2009
    I have the same problem. I took the seat off to wash it and now can't figure out how to reattach it. It's crazy!
  • Anonymous Jan 24, 2009
    Exact same problem here. Help!
  • apruneau Feb 12, 2009
    ahhh... lots of people with the problem no solution
  • kreifsteck Feb 13, 2009
    I have the same problem please help!!
  • sk_1190 Feb 19, 2009
    I'm glad I'm not the only one having a problem. I thought I was just not getting it!
  • fitnutz May 25, 2009
    Did you ever receive an answer to your question about re-attaching the seat to the Evenflo Supersaucer? I recently got one from a friend and I detached the seat to wash it...can't figure out how it re-attaches. Any help would be greatly appreciated!
Nope still couldn't get it following the instructions....Finally figured it out. start with the 3 plastic rings fully assembled on the saucer. Then you need to pull the fabric over the top of the upper plastic ring and then feed the elastic through between the upper ring and the middle ring from the outside to the center through the 1/4 inch space and then attach the elastic bands to the hook point. The fabric needs to be surrounding the upper plastic ring such that your child will not rest against the plastic directly with their head. the plastic tabs are really only for reinforcement, even though they fit perfectly and snap right in the the middle ring (took me a while to get over that).
Posted on Jun 09, 2009
  • juliejuliel
    juliejuliel Feb 05, 2012
    The final step, to save the elastics from slipping or having to hold the weight of the baby is to slide the plastic ring around the elastic into the crack between the upper and middle ring horizontally; this keeps the fabric from sliding over the top of the seat.
I had the same problem and found this on the FAQ section of the Evenflo website. It worked !!!! Now my baby can use her exersaucer :-) The little diamond they are referring to is really really small, but it is there.
Question: How do I put the seat pad on the Supersaucer with the elastic loops? How do I attach the - spacer.gif Answer: 1.Line up the red diamond on the seat pad warning label with the triangle on the back of the seat ring. 2.Fit the elastic loops through the quarter inch gap between the seat ring and rotating rings and hook the elastic loops over the prongs on the bottom of the rotating ring. 3.The plastic tabs on the seat pad are only for reinforcement and don't hook to anything, but should be threaded between the 2 plastic rings. If you still need further assistance please refer to the instruction sheet or call the Evenflo Parent Link Consumer Resource Center at (800) 233-5921 or (937) 773-3971 for further information.
Contact Us
Posted on Feb 21, 2009
How to take the cloth off the seat to wash it
Although I must ada that it's very complicated... If you unscrap the cloth from the top bar, and push the fabric back, there is a prong that you must push in to seperate the bar, from there you can take the fabric off (you will need a small screw driver). AS far as the seat, turn the jumper up-side down and ppush the seat out.... It takes less than 5 minutes to take fabric off but almost 45 minutes to replace after washing, (but it's a must to keep germs away)... :)
Aug 02, 2011 | Kids II Baby Einstein Musical Motion...
I bought a evenflo aura stroller from someone so i don't have the instructions. I took all the covering off so it could be washed and now i am having trouble putting it back together and getting the screws...
Hi Fumbling
You can try this Link, it will lead you to a .pdf manual to save/print/read.
Explanation about washing/detaching and attaching the fabric on page 9 "removing the seat pad".
Hope this will help you out!
Kind regards
Apr 21, 2011 | Evenflo Aura Traditions Travel System...
Reattach seat to Evenflo Exersaucer
Match the red arrow on the fabric seat to the middle of the seat back. Use a crochet hook to fish the elastic straps through the slots. Pull the elastic straps to hook on to the tabs on the lower rotator fastener. The key is to pop the fabric seat up into a cone, so that you can see what you're doing.
Feb 07, 2010 | Evenflo Baby Gear
I cant figure out how to raise the rear seat to get the tire iron out
There is a small loop right next to the rear seat belt attachments. See if the little loop of fabric is hiding inside the hole where the seat belt come out of in the seat.
Oct 16, 2009 | 2004 Isuzu Rodeo
I can not get the seat off Fisher-Price - Rainforest Jumperoo
you will need two people. Flip the top par over and then push in all 4 tabs and push the plastic circle out. Once you get it off the fabric is attache with little button holes. Good luck
Apr 06, 2009 | Toys
I need the attached toys that go with the evenflo supersaucer. Mine is missing four of the attachments.
You can find replacement parts at evenflo.com and some on eday...most Switch-a-roos should works, and you should be able to find replacement clip on toy trays as well. Goto evenflo.com, click on replacement parts, and it will ask you to enter the model number and such. Good luck..
Apr 03, 2009 | Evenflo Toys
How do I attach the fabric seat of my evenflow supersaucer? It was detached for washing and now I cannot figure out how to re-attach it. Fran. email:franblakely@yahoo.ca I have the same problem the...
The seat back should be screwed securely to the other half of the plastic seat ring. Position cloth seat over seat back, lining up red diamond on cloth seat with inverted 'V' notch on lower edge of the seat back. The plastic tab and elastic straps go around outside of seatback and back through the narrow space between the two parts of the plastic seat. The elastic loop then hooks around the tab on the underside of the plastic seat ring.
Mar 30, 2009 | Evenflo Exersaucer Triple Fun Active...
Bottom fabric attachment
Ok I just found the website for the instructions
http://www.coscojuvenile.com/instructions/
Your carseat has the Model # and date manufactured on the side or bottom, type in the date & # and you can download the instructions.
It doesnt specifically address the plastic holds but they DO pop out. If you are facing the front of the car seat you can put a screwdriver under the edge of the plastic peice and turn the screwdriver sideways and the peice pops out. I got all four off.. took some muscle though! Good Luck
Mar 16, 2008 | Cosco Summit 22260 - Bouncing Sheep
Evenflo Jenny Lind Crib Logo
452 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
