Picture gets fuzzy or goes black with slight vibration.
Any vibration near the TV (like when kids are playing in living room) causes picture to get fuzzy or picture will go completely go black and immediately come back on. Is this a normal LCD tv problem? I purchases it at Circuit City with extended warranty. TV is a LG 42" LCD HDTV
  • 52 Answers
It sounds like a loose connection with your signal but if the connection is tight i have seen loose connectors on the small signal board itself which may be resolveable by resoldering connector on signal board which would be far less expensive than replacing signal board itself
Posted on Aug 17, 2008
Mitsubichi VS 45609. When I turn the TV on sometimes it comes on and has beautiful picture and sound. Then after 1/2 or so it goes to a black screen. While on the black screen I am able to PIP it and see...
I have the same TV and what is happing is the TV has 2 recievers in it to allow the PIP, So you have a power pack gone on 1 reciever the other is working, Your set has 2 power packs,1 for each receiver.
I had both of mine go, 150$ a piece to have fixed, good luck.
Mar 07, 2011 | Mitsubishi VS-45609 TV
Picture went completely fuzzy. What could the problem be?
The tv CRT( picture tube) have a radiaton posion infected in ur tv picture tube.This is how u discharge the CRT(picture tube) get the posion out.Take the tv back cover off.Take video board that connected to the CRT(picture tube) out.Plug it in,so u have a live current to the CRT(picture tube).Find a wire like an AV cable,should be find.One side of the metal,grounded to the metal frame somewhere.Take a long needle plier grab the other side of the AV cable wire,not the metal,(Caution high voltage live current).Come very close to the open CRT(picture tube).U will have a live current arc,than u,will hear a big "POP".U,just discharge the CRT(picture tube).The tv now the CRT(picture tube),now it good,it clear of posion infected in ur tv picture tube.Now,unplug ur tv.Put ur tv,back together.Hook up ur tv signal cable and plug in ur tv,now ur tv picture,will be clear,completely.I do this many times to dicharge fuzzy CRT(picture tube).When i was a tv Tech.for the SONY TV Corporation.
Oct 12, 2010 | Sanyo HT32546 TV
TV is nearly 7 yrs old, seems the HD picture is not as clear as it used to be. Is it just me or is something wearing out.
You have glasses,put it on?Tries come close to the tv.Tries few channels that play in HD modes 1080p is it clear.If picture dull slightly fuzzy,the LCD picture screen is getting old in age that all.
Aug 24, 2010 | Televison & Video
GE TV turns on with sound but the picture is black or has fuzzy lines for approx 10 minutes, then the picture comes on and works perfectly
IT IS MOST LIKELY TO BE ONE OR MORE OF YOUR COMPONENTS ON YOUR BOARD I.E. CAPACTIORS RESISTIORS AND OR DIODES THAT ARE BAD OR OUT OF TOLLERANCE.
Feb 20, 2010 | Televison & Video
Fuzzy picture on PS3.
my ps3 just switched from a component tv to hdmi but the screen is fuzzy and off color and i've tried reseting the system but it's not working. help?
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
I HAVE DISH NETWORK HOOKED UP IN LIVING ROOM, I WOULD LIKE TO ADD IT IN BEDROOM OFF OF THE SAME RECIEVER. I USED A SPLITTER, THE PICTURE IN LIVING ROOM IS CLEAR, BUT REALLY FUZZY IN BEDROOM. I KNOW THEY...
You will need to split the signal with a 900mgz splitter between the living room and other room. if your pic is fuzzy you have a bad splitter or bad cable, try replacing these one at a time and it should clear up. If your getting a sat pic but ti is fuzzy its for sure in the line somewhere fro teh splitter.
Nov 16, 2009 | DISH Network ViP 612
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
Problems setting up DvD Play and Wii
TRY DIFFERENT CABLES OR USE DIFFERENT INPUTS. AND BY THE WAY, YOU CAN PLAY DVD'S IN YOUR WII
Apr 05, 2009 | Samsung Televison & Video
Fuzzy and flickering picture
try bending the connectores slightly up and down and check if the problem will be fixed, if that seems to solve the problem purchase anothe AV cord for your PS2 also try testing your PS2 on another tv and then let's see if it will solve the problem
Jul 05, 2008 | Sony PlayStation 2 (PS2) Console
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Electro Med Services...
