Question about Car Audio & Video
I tried to install after market deck in 2002 gramd am non monsoon system and now I have lost all power to the deck, lights, and everythibg else is okay but I got no power.. can you point me in he right direction
  • 39 Answers
You blew a fuse. check the fuse for the dome light or interior power (whatever its labeled as) under the hood of the car. if its a 10amp minifuse and it blows again, replace it with a 20amp minifuse.
let me know if this helps.
Posted on Aug 17, 2008
My JVC cd receiver model Kd R-310 reads protect on the display and won't work. I cut the wires to try to install it in my 2002 grand am. Can this be fixed?
Repair cost would exceed replacement cost. Try disconnecting all the speakers and see if it works then. Try reconnecting each speaker by itself and see if that causes the problem. Most grand am have the monsoon sound syatem...even if they aren't labeled as such. Pull the carpet in the trunk on the left (drivers) side wheel well. The monsoon amp is located over the wheel if you have a monsoon system. If you have to remove the amp then you must change the speakers out or rewire them as the monsoon system uses bi amp speakers. Most of the ga forums have extensive write ups on this system.
Oct 29, 2016 | JVC Car Audio & Video
I have a monsoon mh505 pc speaker system. i lost the power adapter.i need a manfacture phone number or the model number of power adapter.
We can provide one.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Mar 14, 2016 | Audio Players & Recorders
Stereo install yukon w amp and subs
Recheck your connections from deck to "non-sub" speakers. Are you using an adapter from deck to vehicle wiring harness OR are all wires individually connected?
Apr 09, 2014 | 2002 GMC Yukon
Will any 6x9 speakers fit my 2002 pontiac grand am in the rear deck?
I recently helped to replace the rear speakers in a 2001 (or 2002?) Grand Am GT.
It depends on the type of stereo you have. Look at the wires going to the rear speakers. If there are two wires to each, I'm pretty sure that almost any 6X9 speaker will work.
My friend had a Monsoon system, and there were 4 wires at each speaker. There are only a few speakers that can be used on this system. As I recall, the ohm resistance is different from typical speakers. If you have a 4-wire system, you should do some reading at these websites to see what speakers to use:
http://www.gaownersclub.com/forum/index.php
http://www.grandamgt.com/
or try http://www.crutchfield.com/
I did read at one of the above Forums that there are GM replacement speakers (better than original):
"I just ordered two new Monsoon rear speakers from www.gmpartsdirect and they were only $85 shipped. They are a new part number which have been updated with better cones to help prevent blowing, part number is 22698418 " If you go with GM Monsson speakers, also try Ebay. Good Luck.
Apr 08, 2011 | Pontiac Grand Am Cars & Trucks
02 camaro factory wiring set up
Monsoon or no Monsoon. I have the wiring diagram for a 2002 Camaro with no Monsoon system.
May 26, 2010 | 2002 Chevrolet Camaro
Rear speakers blew out in 2001 Buick Regal -How do i remove them?
You have to remove the back "deck" from inside the car
Mar 02, 2010 | 2001 Buick Regal
Installing a Sony CDX-GT09 in a 2002 VW Jetta- power, no sound
definatley amp issue there should be a green wire with a red stripe in your harness, if you take the blue wire with a white stripe from the sony deck and hook it up you should have sound. good luck
Dec 29, 2009 | Car Audio & Video
Wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
May 05, 2009 | 2001 Pontiac Grand Am SE
Cd changer doesnt work
This sucks on multiple levels. If you have the 6 disk CD changer that is part of the Monsoon sound system upgrade, these radios are expensive as all hell to try and replace, not worth it. The really crappy part is that EVERYTHING is controlled through your radio; trip odometer, fuel economy, oil life, and a multitude of of other settings. If you dont mind not being able to see all that stuff, or see any warnings that may come up on the display, then by all means go for an aftermarket deck, but you will probably want to mount your factory radio in the trunk if you ever have to change a setting, or if you had to ever reset your anti theft if it ever becomes activated. The other fun part is that if you have the Monsoon system, wiring your aftermarket deck can be a pain in the *** as monsoon speakers run both a high +/- and a low +/- set of wires, that is why its very expensive to replace a monsoon speaker if you blow one as aftermarket manufacturers do not make them, and or are where you were before, spending alot of cash.
Jan 20, 2009 | 2006 Pontiac G6
After Market radio install on a 2001 Passat
Metra makes a preamp harness that you can use if you have the partial Bose system. My A4 had that (where the front speakers were run off of the headunit with speaker-level feed, but the deck put a line level signal to a rear amp to power the speakers). This harness would let you use the aftermarket deck with your factory speakers, if you have the partial Bose system. Best bet is to do a Google search for "Metra 2001 Passat" or something like that and I'm sure it'll show up.
Jul 31, 2008 | 2001 Volkswagen Passat
Car Audio & Video Logo
63 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
