Question about Whirlpool GD2SHGX Refrigerator
Water dispenser water will not dispense when the pad is pushed. How do I take the panel off to see if something is broken or burned out
  • leah_gea Nov 27, 2008
    We actuaully took the water dispenser pad off while trying to locate the water filter for replacement. Now we can't get it back on to function properly. It is shoved on all teh way but won't push and dispense. Any suggestions?
    Leah
  • 943 Answers
Hi. thanks for the question .you can take apart by pulling gasket back .revealing many screws, but this a job for a tech though. not easy , but so remove screws pull back to reveal switches thanks the appliance doc rate me please thanks
Posted on Oct 01, 2008
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
I have an Admiral side by side fridge freezer model number GC2027HXKW and the water dispenser is not working. The ice is still being made but I cannot get any water to come out
Hello Rosemary:
Are you good with a multi-meter and tools?
You either have a bad contact switch or the mounting pins holding the switch are broken. This switch is behind the dispenser cover. On the bottom of the cover there are two slots for a flat head screw driver to pop the cover off. There are several plastic tabs on the cover sides and top that you must be careful not to break. If you have a plastic round piece where the water dispenses you will have to remove this. Squeeze at the top and the piece. There are tabs that will release. After you have removed the cover there is a touch pad control board - inspect for burn marks. You will need a small screw driver to pry the electrical connector free. Set the cover assembly aside. You will see a green control board. Ground yourself by touching something metal. Static will knock out a control board.
There are several screws holding the board. Remove the board. Know you can see these small contact switches. One on the left side for the ice dispenser and one on the left for the water dispenser. Inspect the housing upon which they are mounted on for broken pins. The contact switch easily slides off these pins.
So, either the control board, the contact switch or it's housing is broken.
Or, you have a bad water solenoid valve. This is located in the back lower left hand corner of your refrigerator. You need to un plug your refrigerator. Pull it out far enough were you can remove the bottom cover. There are 2 solenoid valves. The solenoid valve with the water line running up the back of your refrigerator is the ice maker solenoid, the other is your water dispenser valve. You need to take the wire connectors off the valve. Using a multi-meter check for continunity.
I am sorry I am not their to repair your unit,
Peter
Oct 26, 2014 | Refrigerators
WATER NOT DISPENSING IN DOOR
I am having the same problem. Water pad just click when pushed and ice works fine. Just wondering if you found out what the problem was and resolved it.
Jul 14, 2014 | Jenn-Air Refrigerators
Maytag MSD2574VEM00 refrigerator - ice does not stop dispensing.
Check to see if there is a lock button that will stop the ice from comming out then check the pad that you push on to get the ice and see if its stuck in , there is a switch behind the pad and it will need to be replaced
Jan 18, 2014 | Maytag MSD2756G Side by Side Refrigerator
We have a GE profile side by side stainless steel refrigerator. The control panel touch pad does not function.
The electronics behind the touchpad may have failed. You usually change the whole panel/pod as a single item - could be expensive and perhaps something else has failed, so it could be a waste. First check all connections to it are dry and not corroded. if they are OK Try to buy a used panel/pod on ebay, then change it
Dec 14, 2013 | Refrigerators
Dispenser pad not engaging
Hi; is the refer. still under warranty. Ask the people You ordered the part from. Also sounds like the touch pad has been pushed too hard or to many times over the years and might need to be replaced...alpharome416
Feb 26, 2010 | LG LRSPC2031 Side by Side Refrigerator
Does not make ice, does not dispense water. Can
Sounds like the motor that controls the water flow is either broken or defective. Or the water valve is turned off.
Feb 03, 2010 | Refrigerators
Water dispenser line is broken at connector end in the back of the refrigerator. Pieces of the broken pipe are glued inside the connector. Can we buy a new connector and glue it to the existing pipe? If...
The connector is a push on . Push in on the ring , while pulling out on the broken plastic line . Cut the end of the existing line , and just push into the connector snugly . Uses no glue or adhesive .
Nov 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No ice comes out when pad is depressed.
does your auger turn? thats what pushes the ice doun the shoot. if not replace the auger
Oct 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water filter light
to reset. hold dispense light and lock key pads on the dispenser control panel pushed in for 3 seconds until light flashes. This will reset it
Please rate me.
Apr 14, 2008 | Jenn-Air JCD2389G Side by Side...
Whirlpool GD2SHGX Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
