Hi there. Power down and remove the battery from your notebook. Look along the bottom of the laptop for a plate with slits for air circulation and a label - something like Memory, RAM, C/M. Undo the screws and remove the plate. You will see RAM that looks almost identical to the RAM you have purchased. If it does not, you have the wrong plate. Put it back in and try a different one. Once you can see the RAM, you will notice a pin on each side of the stick. Push both of those towards the outside of the laptop, and the stick of RAM will "pop" out. Pull it straight out along the same angle it currently sits at. To install the new RAM, push the ram in, aligning it the same way the old RAM came out, and then push it down towards the ground until it clicks. Alex
