Question about Nintendo Wii Console
Broken wii hi my wii will not read disc and the screen goes black says that their is a error and 2 remove disc and 2 restart machine please help
  • 344 Answers
Check the disc. If there is no visible scratches then it is the console. It is a very common problem. Unplug all the cables and put the Wii in a different possition. For some reason, when you plug it back in about 30 min later it works! UNLESS you have a bad laser diode which I have repaired also. Then you need a new laser. I hope this helps you out.
Posted on Aug 21, 2008
6ya staff
SOURCE:
When i put a disc ...the screen goes black and then it says error reading disc please press the eject button and turn the console off. what do i do?
The cause here is the Drive itself is ether dirty or showing signes of intermittency now the folks at www.videogamerepair.com can take this into consideration and have it repaired for you if its under warranty or not give them a try. Otherwise you might need to have nontendo get involved.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 03, 2010 | Nintendo Wii Console
Cannot play wii fit plus
Remove the disk, check for any finger prints of scratches and clean the disk if needed,
Turn off the Wii, remove the power cable and let it sit for a couple of min. Then pulg it back in, power back on and then try putting the disk in again.
If it is still giving errors/issues, try doing an update to the wii software in the settings menu and try the disk again after that finishes and the wii has been restarted.
Apr 01, 2010 | Nintendo Wii Console
My Wii is no longer reading a disk. I put it in and I get a grinding sound soon after it goes to a black screen that says "an error has occurred. press the eject button and remove the disk and turn the Wii...
I would definatly contact Nintendo customer support. It sounds like your Disc drive on the Wii is going bad. They will either fix or replace your wii, if it is still under warranty then they will do so at no cost to you.
Jun 22, 2009 | Nintendo Wii Console
Disc Error
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide....
Apr 07, 2009 | Nintendo Wii Console
Unable to read disc.
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Feb 02, 2009 | Nintendo Wii Console
Not reading disc
If Wii gives Disc Read Error, First step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives Information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 30, 2008 | Nintendo Wii Console
New disks won't work, wii doesn't read
If Wii gives Disc Read Error, first step you need to check is totry another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 23, 2008 | Nintendo Wii Console
Error Message
Your Wii is broken. The disc reader is faulty. Return it to Nintendo for repair. I hope it's still under warranty. Best of luck.
Nov 27, 2008 | Nintendo Wii Console
It won't work
I'm getting a similar error. I put in every wii game I own, and every single game had a black error message screen with white text informing me to remove the disk + turn off the power. However, for some odd reason my gamecube games work, as does Okami and Mario Kart Wii.
I will admit I've been incessantly resetting my wii since I'm recording a speedrun, and sometimes let the wii move + shake a lot, though this doesn't explain why 2/10 of my wii games are still working when all the discs are in similar condition.
Aug 24, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
