I have lost file in relation to system32 - Computers & Internet
  • 4 Answers
Your hard disk maybe corrupted, if you have a n operating system disc installer and its cd key you can repair it by running the setup or you can go to the technician near to assist you set upping your computer.
Posted on Aug 17, 2008
In minecarft what does this mean: hs_err_pid#
This error could be related to two things, a corrupt java installation or an issue with the graphics driver.
Try first to reinstall the java engine first, if that fails try to reinstall the graphics driver.
Chances are it is a Java issue.
Good luck.
Jan 22, 2013 | Microsoft Corporation Xbox 360 Live...
Tip
Add Remove Programs list is blank -- Windows 2000
Usually It happens due to some virus activity or any corruption in system files. So when you go to Add Remove Programmes, It shows nothing but a blank space.
· To resolve this issue with Internet Explorer 6.0 installed, repair Internet Explorer 6.0:
Click Start, and then click Run.
Paste the following command in the Open box, and then click OK:
rundll32 setupwbv.dll,IE6Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
Because this command is case sensitive, you should copy the command, and then paste the command in the Open box.
· To resolve this issue with Internet Explorer 5.0 or 5.5 installed, repair Internet Explorer 5.0 or 5.5:
rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
If the Add/Remove Programs tool still does not function properly, shows no content, or if you want to try to fix this issue without upgrading to later versions of Internet Explorer, check the following registry keys to make sure that they contain entries:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache
Note If the previous registry keys are blank, the Add/Remove Programs tool may also be blank.
Use the command line REGSVR32 [path\filename] to register each of the following files:
%systemroot%\System32\Appwiz.cpl
%systemroot%\System32\Mshtml.dll
%systemroot%\System32\Jscript.dll
%systemroot%\System32\Msi.dll
Program Files\Common Files\System\Ole DB\Oledb32.dll
Program Files\Common Files\System\Ado\Msado15.dll
%systemroot%\System32\Msdart32.dll [not registerable]
%systemroot%\System32\Mshtmled.dll
%systemroot%\System32\Mswstr10.dll [not registerable]
If the Add/Remove Programs tool displays incomplete information or is blank, verify the file dates. Where possible, register the following files:
%systemroot%\System32\Gdi32.dll [not registerable]
%systemroot%\System32\User32.dll [not registerable]
%systemroot%\System32\Msvcrt.dll [not registerable]
%systemroot%\System32\Ole32.dll
%systemroot%\System32\Shlwapi.dll [not registerable]
%systemroot%\System32\Imm32.dll [not registerable]
%systemroot%\System32\Indicdll.dll [not registerable]
%systemroot%\System32\Urlmon.dll
%systemroot%\System32\Version.dll [not registerable]
%systemroot%\System32\Lz32.dll [not registerable]
%systemroot%\System32\Comctl32.dll [not registerable]
%systemroot%\System32\Clbcatq.dll
%systemroot%\System32\Oleaut32.dll
%systemroot%\System32\Mlang.dll
%systemroot%\System32\Shell32.dll
%systemroot%\System32\Shdoclc.dll [not registerable]
%systemroot%\System32\NetapI32.dll [not registerable]
%systemroot%\System32\Secur32.dll [not registerable]
%systemroot%\System32\Netrap.dll [not registerable]
%systemroot%\System32\Samlib.dll [not registerable]
%systemroot%\System32\Ws2_32.dll [not registerable]
%systemroot%\System32\Ws2help.dll [not registerable]
%systemroot%\System32\Wldap32.dll [not registerable]
%systemroot%\System32\Dnsapi.dll [not registerable]
%systemroot%\System32\Wsock32.dll [not registerable]
%systemroot%\System32\Plugin.ocx
%systemroot%\System32\Wininet.dll [not registerable]
%systemroot%\System32\Crypt32.dll [not registerable]
%systemroot%\System32\Msasn1.dll [not registerable]
%systemroot%\System32\Msls31.dll [not registerable]
%systemroot%\System32\Imgutil.dll
%systemroot%\System32\Cscui.dll
%systemroot%\System32\Cscdll.dll [not registerable]
Now Restart your system.. and Voila !!
Your problem is gone..
on Jan 24, 2010 | Computers & Internet
I cant find the driver for my samsung intercept. I would like to connect to my computer but the S3C6410 ANDROID ADB doesn't work
Here is what I have found. You cannot let windows automatically install. You must answer no to automatically install and do it manually. So try downloading this link and unzipping it where you can find it. And then point the install window to this .inf file.
a somewhat official answer is all your problem is lack of androidusb.sys, which located in windows\system32\drivers\, it was deleted or replaced by installing some other android related usb client drivers, however, when you install it manually by pointing it to the android_winusb.inf, it do copy the .sys file into system32\drivers\ again, so when come across with this problem, remove target client device keys (with the VID/PID) in registry in currencontrolset/usb/enum, then better restart windows , and run .exe file to install driver or install it manually, and if you can get the right androidusb.sys from your driver directry (for example c:\progrm files\htc...), you can just copy it into system32\drivers\ but complicated.
I cannot vouch for this file but it looks legit. CaptivateADBDriver xp.zip
Feb 02, 2011 | Computers & Internet
How to remove the parasite variant cftmon32 .exe and Ati hot key poller in system32.. HJT v 2.0.0.2 fixes them but they return after 2 or less subsequent scans. Ati hot key poller in system32. always...
cftmon32.exe is a malicious code created to change security processes and registry files and execute different malicious behavior on your computer. Once installed on the PC, cftmon32.exe may automatically carry out mischievous payloads at system start up by creating entries in registry. cftmon32.exe my compromise your privacy and slash computer security.
Follow the given steps for removing virus
1. Temporarily Disable System Restore, Reboot computer in SafeMode
2. Locate CFTMON32.EXE virus files and uninstall CFTMON32.EXE files program. Follow the screen step-by-step screen instructions to complete uninstallation of CFTMON32.EXE.
3. Delete/Modify any values added to the registry related with CFTMON32.EXE,Exit registry editor and restart the computer
4.Clean/delete all CFTMON32.EXEinfected file(s):CFTMON32.EXE and related,or rename CFTMON32.EXE virus files
5.Please delete all your IE temp files with CFTMON32.EXE manually,run a whole scan with antivirus program
Aug 19, 2010 | Microsoft Windows XP Home Edition Service...
How to repair missing wininet.dll?
If you see an error related to the wininet.dll file being deleted or missing, copy this file from the c:\windows\system32 directory of a working Win XP Pro
or Win Vista computer onto a flashdrive, then use the following procedure to copy it onto the failing system.
  1. At the boot screen (the first thing to appear at power-up), hit the F8 function key.
  2. Select 'Safe Mode with Command Prompt' and continue.
  3. In the command prompt window, type the letter of your flash drive, either d: or e: until the drive appears as e:> in the prompt window.
  4. Type 'dir' to see the wininet.dll file on that flashdrive.
  5. Once you see that file, type 'copy wininet.dll c:\windows\system32'.
  6. Unplug the flashdrive and reboot the failing PC.
Once you succeed in reviving the failed computer, go to c:\windows\system32 and right click on the wininet.dll file then copy and paste it to a save name (recommended name: wininet-copy.dll). This allows direct copy of that file back into wininet.dll if the problem reoccurs.
If you suspect an anitvirus engine or some other application deleted this file - and if it occurs again, make note of what was being performed, immediately before the failure mode. This will lead you to the offending program needing attention.
Good luck, hope this helps.
Aug 07, 2010 | IBM NetVista PC Desktop
Had a virus, deleted important system32 filess by mistake, pc wont start up now.please help.
Your System32 files are the most important ones you have. You need to get your Windows disk and boot from it. then you need to hit repair and the files will be replaced.
Sep 08, 2008 | Computers & Internet
Lexmark p450
I found this possible solutions for your problem. Most likely some software installation has messed with the file Scrrun.dll and possibly other WSH files in folder windows\system32, or it's registration. 1)It may not be registered properly. From Start/Run, type regsvr32 %SystemRoot%\system32\scrrun.dll You should now get this message box: --------------------------- RegSvr32 --------------------------- DllRegisterServer in C:\Winnt\system32\scrrun.dll succeeded. --------------------------- OK --------------------------- 2)If this doesn't solve your problem, download and install WSH 5.6 from here: http://msdn.micr- osoft.com/nhp/Default.asp?contentid=28001169
Aug 24, 2007 | Lexmark X75 All-In-One InkJet Printer
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
