Question about Brother MFC-5440CN All-In-One InkJet Printer
Clean ink path to head on cyan color.
My printer prints fine except for the cyan. I have tried new cartiges, self cleaning, daubbing out the ink interface between the cart and the machine.
I had this problem and took a can of compressed air and blew it through the ink receiver (take the cartridge out) I had no yellow, 15 cleanings did nothing, tried this and it works like new. You have to use the long red tube that comes with the compressed air can, and place some pressure on the end of the ink receiver hole before you give it a blow of air.. Try that, give it a few more manual cleanings, mine worked great!
Posted on Sep 16, 2008
I replaced my ink cartridges on my hp photosmart d7260 but the cyans are not printing only the other colors, i have ran the test and clean the heads as stated, also i have unplugged the printer and...
Try using this steps.. I hope it will work, because it works for me. :)
  1. Make sure that the printer is on.
  2. Open the cartridge access door.
  3. Take out the cyan ink cartridge on the printer.
  4. Get a wet clean cloth.
  5. Clean the electrical contacts on the ink.
  6. Dried the ink using a dry cloth.
  7. Put the cyan ink cartridge on the printer.
  8. Close the cover.
  9. Please make a test by going to setup menu > tools > self-test report.
  10. If the cyan ink still doesn't print.
  11. Clean the printhead and align the printer by going in to setup menu > tools > clean printhead or align printer.
  12. If the issue still persist.
  13. Replace the problem Ink cartridge.
After replacing the ink cartridge and your still having issues w/ it. Service the printer or contact HP's printer support department for more options. 1-800-474-6836
Good Luck :)
Feb 06, 2011 | Office Equipment & Supplies
NOT PRINTING BLUE INK
Sounds like the cyan print head is clogged or you are out of cyan ink. You can try running cleaning cycles with your printer or you can try to clean the print head yourself. To clean it yourself you will need dry paper towels and papers towels moistened with warm water. First rub the print head with the wet paper towel, then press the cartridge into the dry paper towel to see the three color bars (a good print head will have three solid fat color bars). Then you can try resting the print head on the wet paper towel for about a minute to get the ink to flow out (do this on a surface that you don't care about, ink stains). Then rub and blot the print head on the dry paper towel. Continue until the cyan flows again (if after 2-3 tries it isn't flowing you probably won't get it flowing). If you go to a Cartridge World store they have equipment to get print heads flowing again and they should clean it for you.
Jan 07, 2010 | HP DeskJet 6127 InkJet Printer
Not printing cyan tryed new cartridge
The print head is clogged.Try unclogging with cleaning tests in maintenance mode.If not help you can try unclogging manually.Warning!!!This can lead to damage of print head.Try it in last case.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left
it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.Call Canon for support.
Nov 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Pixma IP4200- not printing color
If it's a generic ink, try another one, if it's a Canon ink, make sure the tape on top is removed, it covers an air vent, if that doesn't help, you need a new printhead, QY6-0059-000 around $40.00
Jul 02, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cyan Ink cartridge Not printing correctly
After all these tests, then it's defective.
Swap out the cartridge before it damages the printer permanently,
Regards
Ric.
Apr 17, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
MP830 Cyan Ink won't print
I have fixed the problem with my MP830 not printing black. It was the print head. I took the print head out and noticed that the black was clogged.
Apparently as the print head uses such fine jets to get the quality levels up, it seems to be quite common for the print head to become clogged.
There are many ways of unclogging the print head, allot of people I read about used alcohol type liquids to clean with, but I was able to get mine unclogged using warm water, a syringe and some good quality paper towel.
Its a tedious process, but you have to unclog all the dried out ink out of the print head. Some people suggested soaking the print head over-night in water or alcohol, but I was too impatient for this method.
There are two small screws which I undid, this allows the print head to come apart and give you better access to clean. using warm water in a syringe(large needle and body-the type used for re-filling cartridges) squirt water into the offending color hole. you should be able to see all the dried ink comming out.
The paper towel is used to bleed the water and ink through the printhead slots.
If anyone is interested in the method which worked for me, feel free to drop me an email and I can offer some more details, maybe would be easier with a few pics too.
I am outta time, kind of hard to explain in a few paragraphs.
My printer was 2 weeks out of warranty when I did this, there was no way I was going to pay a cent more for a new print head thats for sure.
Use this method at your own risk.
Feb 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Dell color cartridges
this sounds wierd to tell you
take out the cartige and if you can take out the cartige holders ( try to reach for the place where the ink flows out) spray it with a glass cleaning solution and let it pass inside where the ink pases and believe it or not it will clean properly the ink passages. try to clean the bottom of the cartige too.
some 1 trid it infront of me and it worked.
ps: an unproper positioning of the cartige will cause the printer not to work.
Nov 09, 2007 | Dell 924 All-in-One InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
76 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
