Question about GPX MW3837 MP3 Player
Won't play (transfer, format, view contents in explorer OK, though...)
Subj. pretty much describes - if you plug in USB cord, it charges, and you can sync, format & view in explorer. When you unplug, it won't play. Have checked the hold switch & have tried reset button... :(
  • 37 Answers
Does you player powers on? If no, then you have a problem with the battery pack of your mp3 player. If yes, what file system did you use in formatting your mp3 player? If it's ntfs, try formatting it using fat or fat32. Maybe your mp3 player cannot use the ntfs file system.
Posted on Aug 17, 2008
LG Optimus M+ add music
Hello William,
To transfer files using USB devices
  1. Connect the LG OPTIMUS M+ to your PC using a USB cable.
  2. If you haven't installed LG Android Platform Driver on your PC, you need to change the settings manually. From the Home screen, touch the Applications Key Settings > Connectivity > Default connection mode > Mass storage only.
  3. You can view the mass storage contents on your PC and transfer files.
Dec 06, 2013 | LG GT540 Cell Phone
Flash content won't play
Possible that the flash player is not installed or is not supported by the phone model.
you can transfer the media to a more acceptable format that can be opened and seen on the phone.
so transfer the file to your PC and convert it to the required format that will play the file.
Jun 15, 2011 | HTC Cell Phones
Audio files missing
The other files may not be compatible with your player.Try checking the extension of those 133 files that are not showing up in the player.Will wait for your comments.If they are of different format, then try converting all to the same format.Also sometimes the bit rate matters.Too high bit rate files dont play on mp3 players but do play on the pc.
Jan 21, 2009 | Electronics - Others
I cant load music to my lg shine from my computer.. HELP!!!!!!
this might work you might have to try to plug it in to a different usb an see if the computer will pick it up
Jan 09, 2009 | LG Shine CU720 Cellular Phone
Deleting unwanted songs
The Sansa M200 series devices do not allow deletion of downloaded content directly from the device. You must connect he device to PC/Mac via USB to delete downloaded content. You will also need to use media software such as Windows Media Player, Rhapsody, iTunes, etc.. to see all of the music content on the player to be able to delete the songs you don't want. (i.e. just viewing the device in Windows Explorer might not show everything that is on he player.)
Jan 05, 2009 | SanDisk Sansa m240 MP3 Player
Help!!!
It can also be caused by transferring DRM (Digital Rights Management) encoded media files via the drag and drop method. It is recommended that you use the drag and drop method to transfer audio files that are not encoded with DRM. If in doubt, use either Creative MediaSource Organizer or Windows Media Player to transfer your files.
To resolve this difficulty, we recommend that you format the player and transfer the content again. You can also download and install the latest firmware, and select the Format Data Area option during firmware update.
To format a MuVo player, connect it to a USB port on your PC. Open the Windows Explorer, and locate the Removable Drive listing and right click on it. Select Format, and choose FAT instead of FAT32 or NTFS. After the formatting is complete, make sure that you stop your player before disconnecting it from your PC (see above)
To update or reload the firmware for a MuVo player, select the model of your player from below.
This firmware upgrade only works with Creative MuVo Micro N200 players. Do not install this upgrade to other players.
You will lose all content in your player when you install the firmware. Back up any audio or data files in your player to your computer before upgrading the firmware.
Before installing the firmware, please complete the following procedures:
  1. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe.
  2. Connect your player to your PC.
  3. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications.
  4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen.
To install the firmware for your player, follow the procedures below:
  1. Download the firmware update, MuVoN200_PCFW_LF_1_20_04.exe to your hard drive.
  2. Connect your player to your PC if it is not already connected.
  3. Double click the firmware upgrade file.
  4. When prompted to set your player in Recovery mode, disconnect your player from your PC.
  5. Remove the battery from the player, press and hold the Play button while connecting the player to the USB port.
  6. Continue to hold the Play button for about 10 seconds after your player is connected to the USB port.
  7. When the Find New Hardware dialog box appears on your PC screen, release the Play button.
  8. If this is the first time a player is installed as Player Recovery Device, Windows will find a Player Recovery Device (or USB Device), and prompt you for drivers. Click on No , and select Do not search. I will choose the driver to install. Windows will install the necessary drivers automatically.
  9. Double click on the downloaded firmware again (MuVoN200_PCFW_LF_1_20_04.exe) to update the player's firmware.
  10. During the firmware update process, make sure to check the box next to Format Data Area under Download options.
Jan 21, 2008 | Creative Labs MuVo Micro N200 MP3 Player
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Frozen, Can't Access Files in Neeon, not charging either.
first thing first, there are afew things that we had in common; we owned neeon and we both had windows vista.
why vista?
as sophisticated it may seems, vista had so many trouble with the product. I believe that when you try to format the product with vista, it all goes well. everything vanished, the songs, folders, even viruses gone as if it were a new born son. when it all seemed nothing happen, you copy a song on neeon, you unplug it and turn neeon on. voila! no music appeared!
actually, the problem lies with vista itself. the solution is simple actually, no downloading required. while vista can't get the job done, you still had it predecessor, the marvelous windows xp!
just format the product again on your xp. vista can only transfer songs and organize the folders.
old stuff works well with all version of neeon.
believe me, if i had not discover this sooner, i would had trashed my 5 GB mp3.
Oct 12, 2007 | Creative Labs Zen Neeon MP3 Player
"Format Error" after format with windows explorer (XP)
Hello, please check this link: http://support.sony-europe.com/DNA/WM/NW... If you need more info please advice. Arpi
Feb 01, 2007 | Sony NW-E405 MP3 Player
Cannot transfer video clips from FujiPix A 340 camera
Hi chal There is an " add a comment " link at the bottom of the page. please use it next time, because it's better to see the whole history together and not just the latest part. chal wrote " Any one please help. When I try to transfer video clips taken by my A340 fujipix camera to my pc i get the message no pictures can be found. I have no difficulty to transfer photos but not videos. I have Windows XP with service packs 1 and 2 installed. Thanks for any suggestions. " dovi answered: "Movies shot on FUJI's digital cameras are recorded in Motion JPEG format and can be played back using QuickTime version 3.0 or later. (You can download QuickTime from the Apple Computer site). To play back movies in Windows Media Player, download and install DirectX 8.0 or later from the DirectX website. Let us know if it fix your problem,or you need for more help. Good luck !!" Now I try: What are you using to access the pictures? from what I understand the software is looking only for pictures. Try to open it through explorer. Do you see your camera as an external drive under "my computer" when connected? good. Now right click on it and choose "explore", and send us a comment if you see the files there or not. Then all you have to do is copy paste. Good luck!
Jun 26, 2006 | Fuji FinePix A340 Digital Camera
57 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
