Microwave Ovens Logo
Posted on May 30, 2011
I have a Maverick G-120 indoor electric tabletop grill, one of your older models - and I can't find my manual for it. Can you help me?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
64
Points
I have a G-120 i used about 5 minutes ago.. I could scan the manual and email you a copy. Just send me your email.
Microwave oven manual sought
If no longer available you may be able to find it with a Google search. Also check to see if it available on ebay and the owner/seller may just have a manual! U can work something out and get a copy.
2answers
GE Advantium 120 sca1001hss01 stopped working during pre-heating. I had food in oven during pre-heating, no lights at all. power to plug works, could this be a fuse or some other safty switch in the...
It's most likely a failed thermostat.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
1helpful
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
My jvm 1861 oven does not power on at all. how do i disassemble the control panel to replace the fuse
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
The fuse should be accessible after removing only the grille, with no need to remove the controller.
According to a similar model's service manual:
"The fuse is located on the upper duct mounted to the Noise filter.
1. Disconnect power and remove grille.
2. Replace the fuse."
You can find handy exploded views and order parts by model number
here.
1helpful
I just received the Hamilton beach meal maker express without an instruction book. When cooking meat, do you actually close the lid?
Yes you do. If you look at the bottom of the unit you should find the model number. Goto the link below and download the manual for your unit. Should be listed under the Indoor grills option.
Owners Manual
Hope this helps!
Zzeppelinx12
How do I remove my Advantium grill to take off the control panel?
We have the service manual and have uploaded it to our site here to help you.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
1helpful
Model:JVM1631WJ03 Serial: RH900768U How complicated to replace inside bulb. I am a female senior and greatly miss having that light. Also where to purchase that bulb?
It's pretty simple.
It's covered on page 33 of the service manual found online here.
You can pre-order bulbs by entering your full model number (JVM1631WJ03) here.
1 To replace the oven light,
first disconnect the power
breaker panel or pull
the plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
See video here.
3 Remove the charcoal
filter (if present) to
access the light cover
(see Remove Charcoal
Filter section).
4 Remove the light cover
located near the center
of the oven that holds
the bulb. Remove the
bulb by gently turning.
size and type bulb.
5 Replace the light cover
and charcoal filter
(if present).
6 Replace the grille and
power to the oven.
How do i change the bulbs on a jvm1870sk03 microwave
That's covered on pages 35 & 36 of the owner's manual here.
your GE supplier.
or pull the plug. *
to open.
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
1helpful
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
2helpful
GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
