Question about Samsung SC-D103 Mini DV Digital Camcorder
Memory card error
That's it. A San Disk Memory Stick Duo Adapter is used with a 2.0GB San Disk Memory Stick PRO Duo. memory card error flashing on screen
  • cheeks0717 Aug 17, 2008
    I am having the same problem and just downloaded the manual - apparently the camcorder cannot use the "PRO" version of the card, but I cannot seem to find a "non-PRO" card that is in the GB size.
The non-Pro, non-Duo Memory Stick cards maxed out at 128MB. I found some on eBay. The SCD107, which uses Pro and SD cards too, will only read up to 1GB cards. It chokes on 2GB and falsely reads as less than 1GB!
Posted on Nov 21, 2008
    Master:
  • 763 Answers
Did you already formated your memort stick? try to remove your memory card from your camcorder and insert it again. look for the settings on your camcorder. it might cause the problem. hope that helps!
CHARCOIS
Posted on Aug 17, 2008
I am using window 7 enterprise my computer can recognize the sony memory stick pro duo adapter with 1 GB card but cannot open it neither can format it. please tell me any solution.
check the small lock switch on the adapter usually located on the edge of the adapter. check and see if in lock or open position. if its in lock position toggle the switch to open position and you should be able to read as well as write date to and fro from the sony memory stick pro duo adapter. good luck
Sep 08, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory stick may not work correctly
the memory stick has to be formatted with the device it is to go into or it may not recognize it
Format the stick with the camera. If this is a Web cam then format the disk in Windows with a SD memory card adapter. Can be found on Ebay for small price
Apr 19, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
How do i download from a san disk memory stick pro duo - 512 MB? the stick itself is way too narrow and short. help?
Aluratek AUCR200 Card Reader
Please gave a vote, it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Mar 14, 2010 | SanDisk 2GB Memory Stick PRO Duo Memory...
Sony memory stick PRO duo 4gb card says memory full when empty
I would suggest formating the memory card through the options on your camera. If you reformat the memory card and you still get the same error then you have a bad card. Just like anything else the cards will break down internally over time.
Mar 07, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory stick pro duo
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format stick pro duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
My san disk m2 2gb memory chip makes my sony ericsson w205 phone freeze up but when i take it out th phone works fine.
this is a common problem for most of the phones you just insert the 1 gb card which was given to you with the phone
Oct 25, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Stick Micro M2 Memory Card
Don't know the size of the micro with its adapter, but if it is the size of a duo card you should be able to put your micro with adapter into a Pro adapter and this is the memory stick that most card readers accept. Sony has been pretty much backward compatible so I feel this should work. A Pro adapter runs about $10 @ Best Buy.
Jan 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
M2 to memory stick pro adapter
Plug the duo card into adapter labels need to face same direction. Plug adapter into camera or other device label facing you. Once card is installed make sure you format it for the device. My memory stick is 8GB and I use it in my P200 cybershot camera. 2400 high quality 7mega pixel images and 42min-3hrs of mpeg video.
Sep 09, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
Samsung SC-D103 Mini DV Digital Camcorder Logo
393 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
