Canon e000020-00010 error code on my IR8500 - Office Equipment & Supplies
Toner problem , either not getting toner to dev. unit or not reading potenial differential from drum , turn of potential control to isolate issue
Posted on Aug 27, 2008
SOURCE:
What does the Canon IR8500 error code E000222-0000 means?
There's no code like that in my manual.It's220-001 means lamp inverter PCB faulty,or reader controller PCB faulty. There's also a E 225-000 error which mean scanning lamp(xenon tube) is faulty,or inverter or CCD
Oct 14, 2014 | Canon Office Equipment & Supplies
E350-3000 or e350-0002 this error code ,how to solve the error
under ir8500 I can't find the error 350, so exact solution It can't be recommended...
But generally error of 300 type are related to problems with dc controller pcb and only solution is to reconnect the connectors or replace dc controller ( main pcb ).
Sep 15, 2011 | Canon imageRUNNER 8500 Copier
What does error 000111 mean? in canon ir8500
Hello mks. This code means that the laser cooling fan(FM14) has locked and needs to be replaced.You may be able to remove it and free it up as it is most likey locked up.It is located on the front of the machine under the op panel.
Apr 21, 2010 | Canon imageRUNNER 8500 Copier
Hi, I get error E249-0001 on my canon ir8500
This error code relates to a problem between the scanner and the reader board the connector looks like and old printer connector (parallel) try unplugging and reseating this should resolve it.
Mar 04, 2010 | Canon imageRUNNER 8500 Copier
Why better canon ir8500 than canon ir7200
Features - The Canon imageRUNNER 8500 benefits from a number of unique features including 85 ppm output, 4 trays online, 100 sheet document feeder, digital copying, built in duplex , network printing/scanning option, professional image quality and compact and reliable design. The Canon iR8500 can copy or print up to A3 paper size. This high volume copier provides an easy and efficient solution for work groups.
Sep 06, 2009 | Canon Office Equipment & Supplies
Ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Aug 05, 2009 | Canon imageRUNNER 105 Copier
Error code e824-000
E824 indicates an error in the primary charge fan.May be tough to access on an IR8500.Good luck
Apr 06, 2009 | Canon imageRUNNER 8500 Copier
I nedd sst for canon IR8500
i can get you the newest ver. of the SST but i need your email and you have to rate first
Mar 15, 2009 | Office Equipment & Supplies
IR8500 giving E000830-0000 Error code
Having trouble with my IR8500 getting Error code E000218-0000. Any Suggestions? Thanks
Nov 30, 2007 | Canon imageRUNNER 8500 Copier
Open Questions:
232 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
