Question about Sony VAIO PCV-J200 PC Desktop
Vaio TXN19P no audio!
I wonder if you can help me -- all of a sudden, I have no audio no sound no nothing related to audio on my laptop!!
what can i do?? please help!
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Audio problem(s) on any computer system could either be hardware (least likely) or driver issues (most likely).
That being said, you could initially try:
  • change your speaker/headset;
  • verify that the sound device is enabled in your CMOS/BIOS configuration/settings;
  • check Device Manager/Sound Controller, there should be no yellow or red markings. If so, try re-installing the drivers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 17, 2008
Suddenly my laptop sound has gone
Try re installing the audio drivers. go to device manager, sounds and look to see if there a yellow exclamation point next to the sound card, Without knowing what kind of computer or laptop, you have , start there then go to the manufacture website and download drivers and software and get the sound card drivers
Mar 02, 2015 | Sony Vaio Pcg-71312l Caddy Screws
Laptop sound
To start, it may be a longshot, but try turning off bluetooth, in case that is interfering with the sound, or sending the sound elsewhere, like to a bluetooth speaker or cell phone. Also, try downloading the ESET NOD32 online virus scanner using Fireofox, to rule out any pesky viruses messing with your VAIO.
If problem persists....
Open the start menu, and check around for any VAIO support software that can check your system for errors and hopefully fix them.
Open the sound icon next to the date and time on the lower right portion of the screen, and open the mixer, where you are able to see the volume for mic, speaker, and a bunch of other things. Check to see that no mute has been selected, or that no audio has been disabled.
Look inside the control panel, and find sounds and audio. When you open it, click around and see it the wrong audio device got somehow selected, or if NO audio device is selected, and go ahead and select a different device from the drop down menu to see if picking another device fixed the issue.
Next look inside your device manager, and see if the audio device shows up, and hopefully it does, then see if it has a yellow exclamation point next to it. Even if it does not, click on it, and find the option to add or update the driver for it. You may have to insert the restore DVD that (hopefully) came with your VAIO.
The next options, in case nothing has worked, are to do a full reinstall of your Windows OS, drastic but we are at that point. Or else, I have seen instances where the actual sound card in the laptop has died, which would be one reason why Windows no longer recognizes any audio device as being there.
I hope one of these fixed the issue for ya!
Nov 08, 2013 | Sony VAIO VGN-T350P/T Notebook
VAIO TXN19P not keeping time. Maybe Cmos battery??? NOT SURE.
All laptops have a cmos battery, it will be on the bottom of the mainboard unfortunately the only way to access it is to strip your notebook and take out the mainboard if you don't know how to I would advise taking this to a computer repair shop.
Mar 23, 2012 | Sony VAIO TXN19P/L PC Notebook
My laptop left mouse button has stopped working
Common hardware problem. The correct solution is a replacement tracker pad and mouse, however you may be able to get the problem fixed by cleaning under the pad. Either way it requires taking the laptop apart.
WildeFalcon
Feb 06, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
Sony Vaio vgn-fs640w does not power up nor does it
I went to the Sony Vaio support site for your model specifically and they mention a battery recall. There is a place on the site requiring specific information about your system and your battery to see if you are eligible for the recall. I would try this route to see if it resolves your issue. If not, I would say it is a blown transistor and you need to replace the motherboard. This means buying a new system, as Sony VAIO laptops are very proprietary and hard to find parts for.
Good Luck,
NOLA Tech
Feb 06, 2010 | Sony VAIO VGN-FS640W Notebook
Hello, please when i put no my sony vaio notebook, the colors are mixed on my screen, i have changed the screen and the screen cable but the problem is still there
Try taking out one ram stick at a time in between boots. It sounds like you make a bad stick of ram and that is causing video issues. Just a thought.
Sep 06, 2009 | Sony VAIO PCG-K25 Notebook
Sony Vaio wont boot
Hm, maybe your bios battery is dead. Try to buy a new one, and boot than boot it. A bios battery is usually under the keyboard.
Mar 26, 2009 | Sony VAIO VGN-FS715 Notebook
Xp sound driver for sony vaio vgn-n32oe
Check this out "XP audio/sound driver for sony vaio vgn-n320e"
Uninstall your previous installation and install this audio/sound driver.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN320E&upd_id=3507&os_id=7
Feb 10, 2009 | Sony VAIO VGN-N320E Notebook
No audio device on notebook
Cable3,
Sounds like you indeed have a problem with an audio hardware driver. Presumably the 'Audio Device on High Definition Bus' is the system detecting a device it doesn't have a driver installed for.
First question - was the sound working previously? If so, did you recently install any type of audio software not related to the sound device itself?
Please provide the exact model number of the VAIO notebook and we can point you to the correct driver and try that for starters.
Feb 29, 2008 | Sony VAIO PCG-K35 Notebook
Sony VAIO PCV-J200 PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
