Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d56w20 same issues as posted on the 52 rca's /// turns off times and then nothing unless unplugged and the on again. i sat a fan behind the thing today and it played until an hour ago ... now the same as before. i did notice a light puff of smoke from under what has been called the flyback. help please!
  • 1 more comment
  • Anonymous Aug 17, 2008
    rca d56w20 with the same issues as the 52's. i sat a fan behind the tv this morning andit played perfectly all day long until 1 hour ago ... now just like before ... shuts off! i did notice a burnt electronic smell and saw a faint puff of smoke from under what you are calling the flyback
  • Anonymous Aug 18, 2008
    oh, so you are saying that the problem is not the flyback ... but the power supply? thanks
  • jd_smith470 May 18, 2009
    my rca will turn on then off then on and finally off does it about three times whats might it be
    Genius:
  • 2,920 Answers
Your power supply is going or gone out now.DO NOT plug it back in again you could start a fire
Posted on Aug 18, 2008
SOURCE:
50 or 52 inch RCA HDTV about 10 yrs old the power light blinks 9 times then 5 times then 9 times and won't go off unless unplugged, won't turn back on
i have seen this before and sorryy to say if unplugging for 5 or more min and that dose not fix it may need to be replaced not many people fix them these days but not impossable
Aug 25, 2015 | RCA HD52W56 52" Rear Projection HDTV
Hi, my 52" RCA DLP television would not turn off, instead stuck on the first cool down blue screen, and the screen started blinking blue at first and then other colors. Power light blinked 5 times. Had...
I wish I am not retired now I would still have access to RCA or figured it out my slelf.
Unless you are worried about saving electricity Let the thing stay on It will still last for years and cost less then reapair ..Don
Nov 30, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA model D56W20. When I press power, the light flashes 3 long flashes then nothing. No picture, no sound.
I may of seen a different version of this question a few days ago, The set has a 3 strikes and you are out (not a joke) as it will try 3 times when powered up to come on and then go into shutdown.
Most common issue is bad solder connections under the High voltage transformer (see photo of typical one).
Not knowing your skill level let me know how you want to proceed.
Dec 05, 2012 | RCA D56W20 56" Rear Projection Television
Power light flashes 3 times
You can get the CP150, CP120 and Cp114 repair kit at the following link which will usually repair that issue. Its at the bottom of the page under the RCA repair kits. The kit contains the capacitors and detailed instructions how to do the repair. www.tvrepairworld.com
Sep 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D56W20-No Power
NO you cannot. Call a good TV Tech and have him trouleshoot that circuit board and replace the RF connector.
Jul 29, 2009 | RCA D56W20 56" Rear Projection Television
Why does my d56w20 link 3 times with a humming noise
3 Blinks is just saying that there is a problem , and the fault is often concerning teh deflection circuit. The pcb is located behind the back panel, on the bottom left hand side, the firt thing the technician will do is looking for leaky or bulged capacitors in there, checking horizontal and vertical output and testing the the resistors on the deflection circuit.
Jul 18, 2009 | RCA D56W20 56" Rear Projection Television
I have a rca model#d56w20 and the screen is bowing
You probly have a covergence power supply issue. The board is not available the last time I
tried to get one. If it has a stkXXX_XXX type regulator IC it is easily repaiable. I would suggest
a professional tech to repair it though
Jun 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 53" wont power on, please help
The cicuit board behind the power on and off button needs to be replaced.. good luck everyone
Jan 07, 2009 | RCA D52W19 52" Rear Projection Television
Keeps turningoff
I just posted a link for the manual. I would think that it may be solder related. RCA has some issues with their solder especially around the flyback and tuner sections.
Mar 16, 2008 | RCA P52960 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
114 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
