Question about NexxTech (DR30G0) System
DR30G0 system Lost the manual. I accidentally set the video set-up screen to PAL mode. Now my screen is black so I can't see the reset the video mode to NTSC or 'Multi' format? Any thoughts? Also, any idea on how to get an online manual?
  • tick82 Nov 09, 2008
    I also lost my manual can you help
  • 3 Answers
Go to Preference Page, Down 6 lines, right one Enter.
Posted on Nov 05, 2008
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Colors are off
Hi!
maybe your PAL NTSC SYSTEM mode is in accidentally switch to PAL or NTSC try to re switch the PAL NTSC SYSTEM mode.
Nov 02, 2007 | Mitsubishi WD-52725 52". Rear Projection...
The dvd is playing in Black & white
If you are connected to component out from the DVD player, check whether you connected the same color coded to your DVD
If you are using RCA or S-Video, check the System whether it is PAL or NTSC.
Jan 05, 2010 | NexxTech (DR30G0) System
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
A/V in black and white
good day,
what video device do you plug in to your TV screen, DVD player/VCR or game console?
If you still have the owners manual of your TV screen, look for instruction regarding Color system or video system. this menu will allow you to change color sytem from PAL to NTSC or AUTO system.
most likely the reason why you have a black and white color from vidoe input is because of system color compatibilty from your input device to your screen.
Or if your using a dvd player, you can also try accessing the "setup" button and look for video setting. from the video setting there will be selection to choose from: PAL , NTSC, AUTO . always select "auto"
so that the color system of your DVD player can change from PAL to NTSC deffending on your TV screen system setup.
cheers,
mark
Feb 01, 2009 | Sanyo Over-the-Ear Sleek Boom Microphone...
Play back is in black and white
Set your TV in auto mode or according with your CAM system PAL or NTSC and some of the CAM you can set for AV out in PAL or NTSC system
Cheers
Nov 03, 2008 | Sony Handycam CCD-TRV308 Camcorder
When I shoot videos, they sometimes come out in black and white
that is true maybe you accidentally change the settings. or you set the camera to ntsc or pal use either way.
Mar 01, 2008 | Canon PowerShot A710 IS Digital Camera
TEAC Television -CT-M809AV -no picture
Maybe it's something with NTSC/PAL settings, or SOURCE SELECT. Check troubleshooting in your manual.
Oct 11, 2007 | Sylvania 6419TE 19" TV
Black and white picture i did switch my setting to the pal by accident
set the palsecam or ntsc mode! or you have defective board video drive!
Oct 02, 2007 | TruTech TT1620 DVD Recorder
Progressive scan
lpug ur dvd. without turning the power on press and hold the stop button then press the power button
Sep 22, 2007 | Pioneer DV-373 DVD Player
NexxTech (DR30G0) System Logo
345 people viewed this question
Top NexxTech Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
