Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Cannot log on to dwl2000ap
Tried resetting access point but only ssid changed to default and unable to find ip address
If the SSID changed to the default then you know that the router reset to the default settings and you should set your computer to automatically get its IP address via DHCP. I always set up my routers through a Wired connection first, just to setup the router and then go with the wireless. The default for the router should be 192.168.0.1 and subnet 255.255.255.0 . If the computer is set with a static IP address, change it to obtain an IP address automatically or the network card will not bother even looking for an address.
Posted on Sep 25, 2008
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
Hallo, i recently installed and configured a WAp200E-EU-UK access point. i changed the default ip address to 192.168.1.11 and changed the SSID and key, when i logged out of the web interface, i could not...
As you have changed the default IP Address of the router, you can access the router by using the newly assigned IP (192.168.1.11) and new username and password (if you have made any changes to the defaults).
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 20, 2011 | Linksys (WAP200) (WAP200-UK) 802.11b/g...
When I connect my modem dorectly to my pc it works fine with IP address 192.168.1.33. When I go through My D100 I have no connection anf the IP has changed to 192.168.0.100 If I reinstall on dynamic IP...
Improve the Fixya.com experience for everyone by voting!
I think a functional explanation may be of some assistance to you.
The IP address is assigned to the server or client software, but not to the physical workstation which the software or device is installed.
D-Link and virtually every other provider uses IP addresses from a Private IP Address class, which is special class of IP addresses that is reserved for private local networks (not to be confused with Virtual Private Networks, or VPN).
The default IP address is 192.168.0.x and assigned automatically. The most common IP address in any local system is 192.168.0.1.
Over the years, I've found that it is unnecessary to manually TCP?IP settings unless the automatic settings or configuaration has failed When I do have to change the settings, the following are used on Local Area Networks (LANs):
IP Address 192.168.0.1
Subnet mask 255.255.255.0
DNS Do not change
Gateway IP
Address None because the default should be 192.168.1.0 or whatever was
automatically assigned.
Some additional information that should assist you in better understanding a LAN.
The SSID (Service Set IDentifier) is a token which identifies a 802.11 (Wi-Fi) network. The SSID is a key which is set by the wireless network administrator. You must know the SSID to connect to a 802.11 wireless network. However, the SSID can be discovered by network sniffing/scanning. By default, the SSID is part of the packet header for every packet sent over the WLAN.
SSID access points continuously broadcast radio signals which are received by client machines if enabled. Based on the automatic or manual configuration, the client can connect to the access point. A SSID is generally 32 bit long, but when displayed to the user, it is projected into a human readable ASCII format. Multiple access points can possibly share the same SSID if they are for the same wireless network. Many wireless access points support broadcasting multiple SSIDs, permitting the formation of Virtual Access Points. Such Virtual Access Points partition a single physical access point into many logical access points, each of which can have a special set of security and network settings.
SSID Security Issues
Every user of the network must configure the SSID into their system. If the network administrator seeks to lock a user out of the network, the administrator must change the SSID of the network, which will require reconfiguration of the SSID on every network node. Some 802.11 NICs allow you to configure several SSIDs at one time.
Default SSID's
Most 802.11 access point vendors allow the use of an SSID of "any" to enable an 802.11 NIC to connect to any 802.11 network. This is known to work with wireless equipment from Buffalo Technologies, Cisco, D-Link, Enterasys, Intermec, Lucent, and Proxim. Other default SSID's include "tsunami", "101", "RoamAbout Default Network Name", "Default SSID", and "Compaq".
Every time a client connects to the wireless network, the SSID is communicated in plain text format, which can easily be sniffed by eavesdropper using sniffing applications like Kismet. Hence, additional security techniques are required to be implemented in order to enhance the wireless security.
All the best
Ben
Jun 06, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
I want to change the default SSID name
log on the router using the default gateway IP address and change it. if you need more details post router model/make and we'll assist
Feb 02, 2010 | Computers & Internet
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
Cant access to my D-link wireless access point to creat a wep key..what i wana do?
1. Do not attempt to configure your wireless router with a wireless connection. If the wireless connection gets interrupted, you may (probably will) not be able to reconnect to the router.
2. Go to http://www.pingplotter.com/freeware.html
3. Download and install pingplotter. The free version.
4. Run ping plotter to determine the IP address of your router. Click on tucows.com and click on trace. Your router will be the FIRST IP address listed.
5. Write the IP address down. If it is not 192.168.0.1 someone has already configured the router.
6. Log in to your router using a wired connection with the IP address you wrote down. (if you cannot do this due to fthe router being pre-configured by your Internet Provider or other problems, you can force your router to reset to the factory defaults and configure it yourself.
6a. Use a straightened paper clip or similar object to force the router to reset itself to the factory defaults. Put the paper clip in the reset hole next to the WAN connector on the router and hold it for 10 seconds. This will force reset your router.
7. Remove the power from your router for at least five minutes. This will cause your IP to reset his connection to your router.
8. Log back in to your router using a wired connection.
9. The default D-link IP address is 192.168.0.1. The D-link default user name is admin. The password is blank. No NOT blank, just enter nothing but the user name and click on the next button.
10. You should be able to configure the router to your satisfaction.
11. Remember to change the Administrator log on information (name and password).
12. You may find it necessary to duplicate a MAC address in order to connect to your IP.
Nov 24, 2009 | D-Link : DWL-2100AP Wireless-G 108Mbps...
How to install a password in a DWL-2100AP
The usual setup IP address for DLink wireless routers is
192.168.0.1
and the user login = admin and no password is required.
If you have not changed the password and the default SSID then it is recommended that you set a password and change the SSID so that it will help prevent someone hacking into your DLink wireles router and changing your setings to their advantage..
Feb 19, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Dec 28, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
Parkervision wr 1500 ip address
congaman:
You have to connect that 'access point to your machine directly' check for the ip address as the default gateway, assign your machine an static IP from the same subnet, hit refresh in the IE and you should see the log on page of that 'own made access point'.
If the network connections give you sign of exclamation hit repair.
or
THe best option is to refresh to factory defaults, and then start settings as you like to in this access point. Hiding a network is no trouble at all, once you are inside the access point you can reset your security settings as well. So the best option will be to reset the access node.
Hope it helped!
Thanks
Dec 10, 2007 | ParkerVision SIGNALMAX WR1500...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
241 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
