Question about Cyberhome CH-DVD 300 DVD Player
Powering up We plug the unit in to an outlet and the power will not come on. The player is just dead.
Turn the plug around-I had the same problen and just reversed the plug and it worked
Posted on Sep 05, 2008
The unit will not power up, it is plugged in to a live outlet. Is there a fuse or a reset?
FAQ: Blu-Ray, DVD and DVR / DVD Recorder ... - Toshiba
https://support.toshiba.com/support/viewContentDetail?contentId...
ToshibaApr 9, 2013 - Blu-Ray Player does not respond to some operating commands during playback; Random lock up of Blu-ray player occurring after the unit is turned off ...Check to make sure that the unit is plugged in securely to the power source (outlet,... Toshiba BD-Live enabled players offer the ability to allow different ...
PDF]BDP - S185 / BX18 - Sonyhttps://docs.sony.com/release/BDPS185_BX18.pdfSony Corporationray Disc/DVD player is harmful to eyes, do not attempt to disassemble ... Install thisunit so that the AC power cord can be ... Connect the equipment into an outlet on a circuit ... type plug has two blades and a third grounding ... Do not turn up the volume while listening to a ... protection systems used in both Blu-ray Disc™ and.[PDF]Blu-ray Disc™ / DVD Player - Manuals, Specs & Warrantyhttps://docs.sony.com/.../BDPS1200_BX120_S3200_B...Sony CorporationDVD Player. Operating ... in this Blu-ray Disc/DVD player is harmful to eyes, do not ...Install this unit so that the AC adaptor can be unplugged ... Connect the equipment into an outlet on a ... If the provided plug does not fit into your outlet .... Do not turn upthe volume while listening to a .... BD-Live™, BONUSVIEW™, and the.[PDF]Smart 3D Blu-ray Disc™ / DVD Player with Built-in .
Jan 11, 2016 | Televison & Video
No power at all. No lights. just dead
Try plug it into a wall outlet that you know is good. If that's not the problem turn the power switch to on, then test the power cord plug for continuity, if none the power is not getting to the unit, could be the switch is bad, or wire broken/disconnected inside unit.
Mar 07, 2015 | Vacuums
How to test for a shorted generator stator
Sounds like you have a dead short. Check the outlets for any debris, metal or copper. Check the backside if the outlet for anything grounding onto the unit. The breaker is tripping to protect the outlet and anything plugged into it. The fire shooting out of the outlet is an arc flash caused by the dead short. You can also try disconnecting and replacing the outlet . If the problem persists, disconnect the starter and try to bench test it with a multimeter. I hope this helps. Good luck.
Oct 02, 2014 | Briggs & Stratton Electrical Supplies
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
No power, display is dead. Is there an internal fuse that can be replaced?
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if you unit has power, and things lite. it is more likely you have a control/switch problem,
Their is no fuse to replace
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | GE XL1800 1100 Watts Microwave Oven
Dead unit
I'm sorry to hear about your DISH Network DVR-625 receiver. If you don't mind me asking & to allow me to further assist you, what exactly do you mean by "dead unit"," For example, was it working and has suddenly stopped working? Does it power on, can you see any lights on the front of your receiver? Is it plugged directly into a electrical outlet on the wall, or is it plugged into a power strip/surge protector? If plugged into a power strip/surge protector, please attempt to bypass by plugging the receiver directly into an electrical outlet- if plugged into an electrical outlet please try a different outlet. I hope these few tips may help but if not and you need further assistance please feel free to contact me @ Kirstie.Filosa@Dishnetwork.com :)
-Kirstie DISH Network
Oct 03, 2009 | DISH Network DVR-625 DTV Receiver /...
1800HG Gateway Router, no power light
no fuse, the system just may be fried. try the reset button located on the bottom of the unit if no reaction router is dead.
Jul 10, 2009 | 2wire 1800HG Router (RG1800HG00)
SanDisk, 2 GB Sansa mp3 player won't charge
You MAY have a power glich. In which case, hold the power/menu botton down for 20 seconds or more, then connect it to the computer.It's best if you use a USB input that's NOT part of a Multi-USB base, as those DO cause power gliches.
Oct 17, 2008 | SanDisk Sansa e260 MP3 Player
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
Does not turn on
no reset switch but I would bring this up to the store manager where you bought the unit and if he dosent do anything for ya then insist he give ya emersons factory repirs or locate the addy and phone # on the paper work that came with the unit .. if there not totals dreebs the store should exchagange it or have it repaired under warrantee
Apr 05, 2006 | Emerson MS9700 CD Shelf System
Cyberhome CH-DVD 300 DVD Player Logo
62 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
