Hey, i resentley downloaded music to my phone via music sync and it worked fine.. now when i try to sinc my music to my phone it tells me that my phone does not have enough memory. i have a memry card in it and its 2 gigs so i have enough space. I also tried seting my phone on primary storage to external memory . Can you please help i realy whant to listen to my music
Not knowing what kind of mp3 player you have I'm assuming it's NOT an ipod... You're going to need to hook your Galaxy 3 up to your computer via usb and pull all the music off that way. Since it's an android you should be able to browse the contents of your phone from your computer and drag and drop the music on to your computer. From there you'll have to hook up your mp3 player and drag and drop your music from your computer onto the mp3 player.
Another way to do this is if your mp3 player has built in wifi you can sync your phone to cloud storage online and see if you can then download it back to your mp3 player. The first solution is probably easier assuming you can do it that way and don't have to sync your phone to middle man software and then sync your mp3 player to it afterwords. Good luck.
You can add music to the iPad by directly downloading from the iTunes app or by importing your music into iTunes on a computer. Once your music is imported/downloaded into iTunes on a computer, you then just need to sync the music by connecting your iPad to a computer.
If you are using iTunes, point to your iPhone, when connected. In the Device section, from the Music tab, make sure that "Sync Music" and "Entire music library" are both connected. Also, go to Apps tab and see if your computer is, indeed, authorized. And there is a tutorial about sync iPhone music to computer easily, please try to refer it.
1) sync music to your iphone through itunes by selecting the music tab on itunes and select the song you want to sync
2) sync by manually dragging your music to the iphone icon in itunes. you will need to click off the box "manually sync files to iphone" at the bottom of itunes
Music player must be closed and not running in the background when you attempt to sync. Basically you have 2 programs on your computer trying access the phone at the same time. Get the Full User Guide from LG, and set it to "prompt for Mass Storage mode," instead of "Always allow," - and when the media player comes-up on the computer, Deny or say NO, which will let you synchronize.
This option allows you to transfer music files from your PC. In order to use this
option, you must install V CAST Music with Rhapsody on your PC.
1. Open V CAST Music with Rhapsody software. Don’t have V CAST
MUSIC with Rhapsody software? Download it for free at
www.verizonwireless.com/music.
2. Install the device USB drivers before connecting your phone to
a PC.
USB Cable and Device Drivers can be purchased separately via the Music Essentials
Kit compatible with this device.
3. From the main screen on your phone, the SYNC MUSIC V CAST
MOBILE PHONE display appears. Your phone should display the
message: Connected.
Connection may take a few seconds.
4. Drag and drop the song(s) you want to sync from My Library, to
your V CAST Music with Rhapsody mobile phone, listed under
the Sources tab. Once synchronization is complete, press the
END/Power Key and disconnect the USB cable (purchased
separately).
5. Under the Music & Tones menu, open My Music to view and play
your music.
• A compatible USB cable (sold separately) is required for syncing.
• Music can also be purchased via V CAST Music with Rhapsody through your PC. Hope this helps, let me know if I can help you with anything else. JimmyC
It is quite a bummer, but you have to select one picture at a time, go to options, select move, choose memory card, select paste and then when you have moved all of your pictures over to your memory card you can get them on your computer via the data cable. I miss my sony!
Only a hint. Did you check the small print via the downloads for Pocket PC on the Microsoft web pages? If you download from the regular OS pages they don't mention that certain Pocket PC generations are not supported.
I noticed this but only on Media Player downloads fom the pocket PC pages but it takes time to find this more detailed info.
http://www.microsoft.com/windowsmobile/resources/downloads/pocketpc/defau
lt.mspx
