Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE PROFILE FRENCH DOOR 3 YRS. OLD
CLICKING SOUND FROM CIRCUIT BOARD ON BACK OF REF. FAN NOT RUNNING COMPRESSOR GETS HOT . REF. AND FREEZER NOT COLD ENOUGH . REF. AT ABOUT 50 DEGREES.
  • Anonymous Mar 17, 2014
    the freezer is getting cold but the ref is not
  • 725 Answers
Sorry you have a bad control board
Posted on Aug 17, 2008
Maytag refrigerator not cold.
do you have a full frost pattern (coating) on freezer coils or see a ice ball, if ice ball Leak in system or bad valve in compressor. not worth fixing. go on (repair clinic .com).
you have a dampener and a fan to let the cold air go to all the areas check to make sure fan is running push in light switch in freezer and llisten for fan could be problem or no power to fan from main control board.
Dampener is flapper door that lets cold air from freezer go into ref. section
are your doors sealed, gaskets, frapper between door on ref section closing.
also your return air ducts need to be clear of ice, is your ice maker working that means that it is below 10 degees and repairable.
May 03, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
Not cooling. i do not hear the compressor. fan is working. 3 yrs old
The condenser fan is very quiet so you may not hear it . remove the lower rear back panel and check whether the compressor and or fan is running . Also check if the back wall of the freezer has frost on it or if the evaporator fan in the freezer is running.
Nov 12, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Hi, I am looking for a bit more information on troubleshooting GE Profile cooling issue (it is a PFS22MBSBWW model - french door, bottom freezer white on white), less than 5 years old. So the issue is...
Did the "tech" try and jump start the compressor? Testing for shorts won't tell you much, especially if there are no shorts. You say its clicking and the fan is not working at all, which fan are you referring? The one near the compressor? Furthermore, since you didnt describe what refrigerator and freezer temperature problems you were experiencing, I can only assume nothing was cold anywhere. However, since the compressor was very hot, and not starting, eliminates the control board being at fault, as it is energizing the compressor circuit. Additionally, since your "tech", and I do use the term loosely, but since he either didn't know how to jump start the compressor, or doesn't have the equipment to do so, you will either have to get a better refrigerator repairman to test the compressor, or bite the bullet, buy both the compressor relay and overload, and hope those were the problem and not the compressor itself.
Nov 04, 2010 | GE Profile Bottom-Freezer Refrigerator...
Freezer is warm at top and cold on the bottom.
Sounds as tho your evap fan is not running. Open door to freezer and should hear a fan running smoothly. If not most of the time the problems is with the main control board on back of refrigerator.
Jan 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile atrica not getting cold enough
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | GE Profile Arctica Stainless Steel Top...
Ge profile buttom freezer cold refrigerator hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Dec 16, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
105 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
