Question about Zenith ZEN350 Remote Control
Zen350KD remote control
I need the code to work a Symphonic tv/vcr cmbo. Please help thank you
skippy101
  • 143 Answers
SOURCE: I forget the code...
Zenith
153, 154, 172
Posted on Nov 04, 2007
SOURCE: Zenith ZN-501S remote control codes and instructions
http://www.thompsontv.com/zcodes.html
Posted on Feb 20, 2008
IrishDruid
  • 2712 Answers
SOURCE: Remote control codes for Symphonic tvcrg13
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 19, 2008
SOURCE: wHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Posted on Feb 03, 2009
SOURCE: I need the remote control codes
Codes for OneForAll URC-7030
Sony:
1505
0505
1651
1010
0011
0036
0102
0074
Procedure:
- press the "tv" button
- press and keep pressed the "magic" button until tv button blinks twice
- insert one of the codes
- try to switch off the tv set: if this works, press "magic" again to confirm the code.
Otherwise, proceed via automatic search:
- press "tv"
- press and keep pressed "magic"
- dial "991": "tv" button will blink twice
- press "tv" then press the standby button on the rc, repeating this last step until your tv set turns off. this may take several "tv>>standby" pressions.
when your tv set responds properly, press "magic" to confirm".
Posted on May 09, 2009
Need instructions for codes for jumbo remote for symphonic tv with vcr
Hello
Setup code for Symphonic TV/VCR with Jumbo remote control is: [002].
There is no setup codes for TV/VCR combo with RCA RCU600M remote control. OK.
Aug 14, 2011 | RCA RCU600M Remote Control
Sirs and mesdames: I have a Symphonic TV/VCR COMBO model # TVCRI3E1. The remote control part # (UREMT32SR007) is missing. Where can I find a replacement? Thanks, Ilia Rivera
Hello
Just buy one Philips Universal Remote control Model number [CL 034]. You can synchronise it with your Symphonic Combo by entering one amoung the following codes. Proceedings are also given.
Note: Switch OFF and Switch On your combo, before entering each code.
Three digit codes for Symphonic are:-
033/ 053/ 189
Four digit code for Symphonic TV/VCR combo is:-
0227
Four digit remote codes for Symphonic tv are:-
0053 0189 0227 0456 0024
Four digit codes for Funai are:-
0051 0189 0053 0227 0456 0042
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
You can also check according to the catelogue of that remote control also. The above given numbers are most common for all universal remote controls. OK.
Dec 24, 2010 | Funai Televison & Video
I need the code to reprogram my Symphonic tv/dvd/vcr with a GE Universal Remote 24944
Symphonic tv codes are 0053 0189 0227 0456 0024
tv/dvd combos 0456
dvd/vcr combo 0456 {0458 & 0227}
{0899 & 0236}
hope this helps if not i can scan the code list for you
Jun 16, 2010 | Universal Remote Control GE174Universal...
In need for remote code number(s)
Yes I have solved my problem. Thank you very much for the help. I came across a web site that gives you the TV codes so I can program my Direct remote.Thank you again.
Mar 31, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
Symphonic codes for rca rcr450
Download the manual and look at the back pages =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
Codes for Symphonic TV on Page 39
Symphonic TV 1026, 1033, 1038, 1046, 1155, 1189
Codes for Symphonic TV on Page 40
Symphonic VCR 2026
Good Luck!!
Jan 01, 2009 | RCA RCR450 Remote Control
Systemlink 3, code number for symphonic tv
I have a Symphonic also and I was able to program it to watch TV using the dfirections on teh inside of the battery door. Try it! I can't get VCR to work though.
Jul 01, 2008 | RCA RCU300WBL Remote Control
Please help!!!
Try the remote's "search" feature. If that does not work, then the remote doesn't have a code for that unit.
Hope that fixed ya...
Geno
Mar 28, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Zenith ZEN350 Remote Control Logo
363 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
