Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
Maytag neptune washer: will not start
Maytag neptune washer: all buttons and indicators are working - except the start/pause, signal, and off button. The start/pause and signal indicator lights are out and neigther these nor the off button will work. So, the washer will not start. I would like to fix this myself. What should I do? Buy a new switch panel and install it? or is there a test I should run first?
  • 751OP Aug 17, 2009
    The outlet was working. I found a broken 'wire' in the instrument pannel. Since this wire was part of a a 'printed circuit' board, I had to buy a new PC board for the instrument pannel. it set me back a few bucks, but it has been running with no problem ever since. Apparently this is a common issue on the model.
    Problem Solver:
  • 11 Answers
Plug a light into the washer outlet to check for elec current at this point before anything else.
Posted on Dec 28, 2008
Start button does not work
the door switch could be bad ,it has to work in sync with the start button
Nov 10, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag
try and unplug the dryer from the wall ro reset.
May 28, 2013 | Dryers
I stopped using the "pause" button, with a little water in. Now it will not restart. I have turned completely off, yet it will not restart.
by holding the SIGNAL button for 3 seconds, the PAUSE button for 3 seconds and then walking away. It restared within about 5 seconds.
Nov 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine wont restart after inadvertantly hitting the stop button instead of the pause button
I believe the final solution was to unplug the machine for several minutes. When it was plugged in again I hit one of the wash cycle buttons and after a minute or so the button indicating that the door was closed properly lit up and then the machine resumed it's cycle.
Aug 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Maytag Neptune TL Washer
if this worked fine before, then I am only guessing that the water inlet valve has malfunctioned. try filling the machine with a garden hose...any change? if still no go, then be sure to have a shop-vac handy to remove the water you just added.
May 30, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
1,000 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
