Question about RCA P61960 61" Rear Projection Television
Rca p61960 projection tv
It looks like the picture is to big for my screen,on the left hand side the picture bend and a little bit out of focus on that same side ,could you help me please,thanks
  • 30 Answers
That sounds like a Pincushion problem if you having bowing. It's probably bad caps and diodes on the deflection module. This is not an easy fix. If you know how to read a diode and you visually inspected the caps you might have some chance of fixing it yourself.
Posted on Oct 14, 2008
My picture is to big for my screen
What happened? Were you disconnected from the chat? Anyways try this , you see 4 directional arrows right? Press the left arrow to zoom out the image. I am assuming that your new remote has this function. Try it and let me know
Nov 12, 2010 | RCA P61960 61" Rear Projection Television
My rca tv the picture is bending into the center of the screen and the letters are double and colors are off
Press Menu then setup Look for Convergence,If you do Not See It listed then you have a Blowed Fuse FL231 on the Deflection Board.
It will be Located on the bottom left hand side Board with FBT flyback Transfomer on the right side of the FBT Look for 3 in a roll small brown looking caps ,These are Fuses, It will be the one in the Middle 0.06amps Partstore.com has them 1-866-925-7278
Oct 05, 2010 | RCA D52W23 52" HDTV CRT TV
RCA P61960 Picture is concaved
this is the conversion chip or sometimes chips that cause these effects the chip or chips are about $30 each but labor is alot more $250 -$300
Oct 18, 2008 | RCA P61960 61" Rear Projection Television
RCA P60752EBLG1 Convergence Problem
If you wish to get some details; visit the site linked here. Pull up older posts.
Convergence adjustment to projection TVs are given.
Apr 24, 2017 | Televison & Video
P61960
I was tring to remove the concave off my screen and came across a setting where you can make the picture larger or smaller. On the TV, not the remote, press and hold the menu button, press and release the power button, press and release the volume up button and release the menu button. P0 and V0 will be displayed on the screen press the volume up button until the V0 is V76. Press the channel up button until P0 is P11 and press the volume up/down button to make the picture larger/smaller. If you need to center the picture press the channel down button until P11 is P10 and press the volume up/down button to center your picture. I hope this helps
Aug 18, 2008 | RCA P61960 61" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
My rca tv
im having the same problem on my RCA P61960 61" i just moved and it might have got bumped a bit not sure but when i try to use my component video hook up i get a blurry distorted picture for a few seconds then i get an unusable signal message if i change my input to just cable it works fine please help
May 10, 2008 | RCA P61960 61" Rear Projection Television
TV Turning on and off, left side of picture is not lining up, bowed in center
Most likely you had a power surge issue that caused the tubes in your crt projection to malfunction. I would recommend having a service call done to find out the issue
Apr 22, 2008 | RCA P61960 61" Rear Projection Television
Colors are in three
Convergence ICs need to be replaced.
Feb 03, 2008 | RCA P61960 61" Rear Projection Television
Picture too big for screen
if anyone has this p61960 television that does not work anymore, I am looking for parts for mine and would buy, please let me know, thanks
Oct 14, 2007 | RCA P61960 61" Rear Projection Television
RCA P61960 61" Rear Projection Television Logo
170 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
