Question about Samsung P30 Notebook
How to Disassemble a Samsung P30 notebook keyboard and the strip above the keyboard
    Filmmaker:
    Uploaded 5 video answers.
  • 5 Answers
Maybe this video is helpful:
Posted on Jun 27, 2010
  • 4 Answers
The P30 has 2 screws on the base of the Laptop marked KBD - remove these with a small philips screwdriver (size 1 is good).
Then with the Laptop open, look at the top of the keyboard, there is a gap between the keyboard and plastic strip. There are 3 little black tabs holding the keyboard top edge down, these are above the Ins, F8 and F1 - use a small flatbalde screwdriver to push these upwards to release the keyboard. The top edge should lift up towards you.
be careful to disconnect the ribbon cable attached to the motherboard by lifting the edges of the plastic connector to release the cable.
With the keyboard removed you should see 3 screws holding the plastic strip in place - remove these with the philips scredriver and the strip should be removable with a snap upwards. Be careful not to damage the plastic covering the hinges.
Posted on Feb 09, 2011
  • Samsung Master
  • 32,281 Answers
The plastic strip above the keyboard may be secured by a screw on the back edge of the laptop with a screw located behind the screen hinge. If there are no screws then it is just clipped in place, slide a thin blade under the plastic cover that covers the screen hinge and gently level up until the it pop up, there may be a ribbon cable connecting the switches and LEDs.
Depending up on the model of the laptop, the keyboard may have screws that is located under the plastic strip or it may have screws that are located on the bottom of the laptop, usually 3 or more screws directly under the keyboard.
Posted on Jul 27, 2009
Drivers
You can download the device drivers from the Samsung WEB site. Please click on this link and select your model computer/notebook and the Windows drivers you require :-.
http://www.samsung.com/us/support/
May 08, 2013 | Samsung P30 Notebook
HELP Samsung sens p30 audio driver
You can download the audio and device drivers from the Samsung WEB site. Please click on this link and select your model computer/notebook and the Windows drivers you require :-. http://www.samsung.com/us/support/
Sep 16, 2012 | Samsung P30 Notebook
I want to upgrade the internal ram on a samsung p30 laptop
If it has a second slot, it will be under the keyboard and you will just need to remove the keyboard. Typically there will be 1-3 screws on the back of the computer labelled with a K, and or you need to pry off the bezel on the front above the keyboard which also may have screws on the back holding it in place. Along the the top of the keyboard under some keys you may see holes, these are pry holes. Be careful though it is easy to break clips.
Jul 09, 2012 | Samsung P30 Notebook
Drivers downloads for samsung corona sens P30
You can download the device drivers from the Samsung WEBsite. Please click on this link and select your model computer/notebook and theWindows drivers you require :-.http://www.samsung.com/us/support/
Jun 10, 2012 | Samsung P30 Notebook
Samsung Q430 keyboard removal
Keyboards are simple to replace. Remove the power cord, remove the battery. Turn the laptop over and look at the screws on the bottom case. If you see a screw that has the icon of the keyboard next to it, remove that screw. Look inside the Battery Case there might be screws it in. If so remove them because normally those screws hold the strip that is above the keyboard and there might be some in there that has the keyboard icon next to it.
Turn the laptop back over and open the lid. Pry the strip that is above the keyboard off gently because there might be a cable on it. On most systems the strip above the keyboard will be where the power button is.
Once you have the strip above the keyboard removed look at the top of the keyboard and there might be screws to remove that the strip was hiding. There might be little catches that key the keyboard in place located along the side or at the top. Gently work the keyboard out because there is a cable behind the keyboard that you will need to remove.
That's all there is to it.
May 04, 2012 | Samsung Q430 Laptop
Want vga drivers for samsung p30 notebook
goto website: http://www.samsungpc.com/products/p30_p35/p30_p35_supporteddrivers/p30_supporteddrivers.htm
Mar 27, 2012 | Samsung P30 Notebook
I have to download audio and video drivers pls .and my loptop is a samsung sens p30
You can download the device drivers from the Samsung WEB site. Please click on this link and selectyour model computer/notebook and the Windows drivers you require :-. http://www.samsung.com/us/support/
May 15, 2011 | Samsung P30 Notebook
How to disassemble Samsung R510 notebook?
Dear ,
To removw the Key board you need to remove three screws and after that you need to remove from top side of keyboard.
You need to remove the screws from base and latches.
I recommend you to refer the same to service center because the mechanical damage will not be covered in future.
Mar 09, 2010 | Samsung P30 Notebook
My @ key on the keyboard is not where is should I have to use the number 2 key which should be " but appears to be the @ key so how do i change
go to configuration ,country , select lang ,and details and ad the richt keyboard settings
britich are the @ at your richt in the 3 row from keyboard and unitestates are the @ under the 2
ther you must chanche the configuratie for the keyboard
Dec 13, 2009 | Samsung P30 Notebook
Samsung P30 Notebook Logo
2,135 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
