Question about Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg code E8
Dishwasher runs for about 6 seconds then stops with code E8
  • murielmis Oct 19, 2008
    machine starts and stops after a few seconds showing E8
    Problem Solver:
  • 6 Answers
Thanks to hijoloo for pointing me in the right direction. The offending part is the diverter valve, a paddle inside blocks one of two outlets in turn actuated by a micro switch, a motor and reduction gears. Check switch for continuity with multimeter (ohms) then check motor and gears turn freely by hand. My problem was a stiff paddle due to limescale. Soak in boiling water to free off then oil cog (externally) and rebuild.
turn the washer on its side and open up the bottom black plastic plate, than disconnect the two black hoses from the white pumphouse in the middle of the washer. disconnect the connector and open carefully the housing by removing two screws and the motor. check the switch and clean the white housing. Check also if there is nothing inside the rotorhouse. after this build every thing back and hope that its running. it worked for me. succes!
hijoloo.
Posted on Nov 19, 2011
I have exactly same problem. Have you solved it yet..
Posted on Aug 30, 2008
My GE dishwasher is showing an E8 code...my dishwasher will not start. What can I do?
Maybe try unplugging it for a minute or so and plug it back in.
Jul 26, 2016 | GE Dishwashers
Where is the distributary valve?
that is a very good question
i cant find a "distributary valve" for sale
lots of water inlet valves hot and cold single units
almost every dishwasher user manual and has code e8 mentioned and faulty distributary valve
why the fault
.If the distributary valve have worked for 150
seconds, and could not reach right
position during wash cycle,after the cycle is finished, the dishwasher will shut off all
loads, the alarm buzzer will ring for 30 seconds and the window will display "E8" at rate
of 1Hz in 30 seconds, and then display "E8" , drain water for 2 minutes meanwhile
May 12, 2016 | Dishwashers
Error code E8 appears mid wash, heater is working ok, machine has been hooked up to the hot water instead of cold. I have since directed cold water through water valve.
hot water form the house takes less power to bring up to machine temperature so by hooking it to cold water will increase the power consumption
call a service center and get the explanation for the error codes and that will explain what is faulty
you didn't mention the make and model of the unit and every error code appears different
for example in a fulgor milano machine code 8 is failure of orientation of distributary valve ===causes open circuit or break of distributary valve
for hoover nextra e8 is dishwasher has failed to heat with water in a reasonable time or has failed to detect the water heating element===causes check water heating element/wiring--check wiring to main control module
go google and type in-- dishwashing machine error code 8-- and see if there is any site for your machine to get the error code and causes
other than that get in a service technician for a correct diagnosis and fix
Apr 23, 2016 | Dishwashers
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
Was awakened in the middle of the night by the F&P dish drawers (top drawer) playing the "Star-Spangled Banner" alternately with "Brahms Lulliby", lights flashing, lots of beeping! .....the lights...
Not funny Cindy - Any chance you can access the power breaker in the panel for the dishwasher? Sometimes with even short power bumps or outages, electronic controls get out of whack - Leave the breaker off for a minute and then turn it back on - As for the water level, I would question if the hookup was done entirely correctly - The idea is for the drain to connect to the most clear point of the sink drain - if you drain came with a pre-made Dishwasher drain connection, did the installer make sure that the plug was fully removed before connecting - Even in my mobile dishwasher I might get an inch of water, but not what you are experiencing - Good Luck
Feb 09, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
E8 error code on smeg dishwasher
Jun 07, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
DWF614SS smeg dishwasher E8 error code
hijoloo.
Apr 12, 2010 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg 24 in. DWD1SSE-1 Built-in Dishwasher Logo
973 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
