At this point the best thing to do would be to recalibrate the scanner. I don't have the service codes with me right now to do it. I'm hoping the C250 runs like the C350.
I won't have access to that info until Monday morning.
The friend, from whom u took photos may hav virus in his cell phone. Thus the pics he sends u also have viruses and bad sectors so ur cell phone is unable to display photos... Share photos from any other friend and check. If the same problem occurs then ur cell phone have viruses... So backup all ur data and restore factory settings... May this helps!! Thanks..
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
You can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
read the package box of your printer. If it has windows NT printed on it then you can, because it needs compatibility driver to run your printer. But if it is a desk-jet or inkjet you can install whether you are in NT or other os.
Hi Agbri,
In case u have`nt solved your problem yet, i had a radio i could`nt use for 3 long years then i found these codes on a web site, the very last number unlocked mine:Try each one:
4316-2152-4513-4362-1156-1165-2145-3451-6361-5624-5241-3346-4524-5436 & my favourite- 3241
Good Luck: Jenny
Have you tried doing some maintenance like nozzle check,printing head alignment,clean the nozzles if not then try it by going into control panel - printers and faxes - where you see your mp730 right click and go to properties then click on the last tab which would be maintenance.Try those options if none worked then u might have to replace you print head and that should work
