Question about JVC AV-48WP30 48" Rear Projection Television
I have the same problem with my jvc with the double letters and numbers how can i fix this
Double numbers in later and a red and green shadow in left corner of tv
  • Hockey15 Sep 07, 2008
    I have double numbers and a yellow and blue wave in the top left corner showing double. tried the convergence screen and that shows blue cross's out of line with the adjustment cross. not sure how to adjust?
Go to the convergence screen on your settings and adjust with the arrows to the box showing in the middle of screen. This just happened to me thre a lightning strike and will work and its easy.
Posted on Aug 24, 2008
  • 3 Answers
Did you attempt to repair your computer on your own and then started to have this problem or did this just suddenly happen? Also, can you post a picture of what you are seeing?
Posted on Aug 20, 2008
SOURCE:
My hitachi 50v500 has double letters/numbers... picture doesnt seem to be alligned properly? Everything has a matching shadow just to the left.
I am answering this because I know this set and do not like the answers you have received.
If you see a slight "ghost" to the left or right of lettering--it can be corrected with the remote--there is a exact way to do this--I have done it before and have instructions based on a service bulletin from Hitachi.
Confirm you have the ghosting to right or left of letters and I would be happy to post the instructions to correct that--all of it is done with the Hitachi remote that came with the set.
If you decide to do it I will give you the instructions and help you do it.
I have helped 4 other people here with the exact same set and problem.
Understand that not all people here know what they are talking about-I am sorry you got a poor answer, but I know this set well.
You want to fix it for free? I can help you.
Keep in mind I am in California and possible time differences.
Regards, SD TECH
Jan 01, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Looks like 3D Picture
You probly have a convergence cicuit failure. Replacing the convergencr IC's will probly fix it.
I recommend a professional repairman to
do it though. Particularly if it needs further adjustments after the IC's are replaced.
Jun 16, 2009 | JVC AV-48WP30 48" Rear Projection...
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
Blurred TV - double vision with red hue
I was searching online about what could be the problem with our TV and I came across your page. We have a 52" JVC Projection TV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur.
If you have any suggestions on what caused this and what we can do to have this fixed, I would greatly appreciate your advice.
Sep 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Red and green shadows
Your tv has a convergence board problem. Have a technician replace the convergence IC's.
Jul 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
I have a phillips rear projection 51PW9303 red and green lines showing in the left corners and red line thru middle of screen, bottom of screen shadows and so does left top corner if numbers and...
sounds like youre describing a convergence problem. Do the letters look like theyre 3D? If so you will need to replace both Convergence ICs STK392-120 you can get replacements at the following link and they include installation instructions with pictures plus gree tech support. heres the link.
http://servicemanuals.vstore.ca/
Apr 24, 2008 | Televison & Video
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP30 red "shadow"
The problem called Convergence problem. Unfortunately, some sets have manual convergence boards - which means you can do nothing but replace it and adjust the manual controls on the board itself. But some of the newer ones (Maybe yours) can be accessed through a service mode. So, give it a try and look for a service mode in your set... Good luck!
Jan 02, 2006 | JVC AV-56WP30 56" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
78 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
