I have an Apple G4 and after 6 years of faithful reliable service, just recently what has started happening is after switching on the computer it boots up normally but then after a few seconds the monitor screen goes blank and the message "No input signal" appears, then the screen switches back to normal, then goes blank again with the same message. The computer never crashes or freezes, but the screen goes blank back and forth. Then the screen settles into a strange fuzzy picture with the normal lettering ie File Menus etc becoming oversized!
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
I'm trying to install this program and it says I don't have the DVC100 disk or something, am I...
(More)
I'm trying to install this program and it says I don't have the DVC100 disk or something, am I supposed to have bought a seperate disk to install it? Also when it gets to the part where I can "Select total recording time: Automatic, Good Better or Best" the section won't let me type in the minutes to "Start Recording" The camera I'm trying to get the videos off of is a Sony TRV57 it's pretty old- is this why I'm having the problem, is my camera too old to work with this software?
Just installed the e-Geforce 6200 to replace an original equipment bad graphics card on Dell 4600...
(More)
Just installed the e-Geforce 6200 to replace an original equipment bad graphics card on Dell 4600 (2.6GHz, 2 Meg RAM, Win XP). Having a terrible time with problems with scrolling delay and choppiness. Either with mouse wheel or scroll bar. With scroll bar sometimes even get a short hourglass. Screen paint is slow and screen scrolls as if it were multiple pages not one big page. Occurs with IE as well as some MS applications such as Word. Tried IE with and without Smooth Scrolling with no difference. This delay is really frustrating and makes it hard to use this PC.
9-SOCKET_DATA . LOOKUP(S) = = O CAPTURELSPNOISPWSP_PATCHES.CPP:1313 IEXPLORE.EXE ASSERT IN LSP tHIS...
(More)
9-SOCKET_DATA . LOOKUP(S) = = O CAPTURELSPNOISPWSP_PATCHES.CPP:1313 IEXPLORE.EXE ASSERT IN LSP tHIS IS A READING i GET, WHEN MY MONITOR, MESS'S UP. IT SEEMS THAT WHEN MY COUMPUTER IS COLD(JUST TURNED ON) T5082-eMachines. It (bilt in ATI) don't have enough power? to run the screen AOC- lcd monitor it worked fine at first. but when windo's started down loading all there up dates to fix Vista, it got a lot worse. I have wavey line's on screen can't read any thing for about 15min. OK I gess or hope I'v given you enough info. ? Thanks , James
i use nvs 280 for over two years. but for past two months, my system hangs. if i take out the card...
(More)
i use nvs 280 for over two years. but for past two months, my system hangs. if i take out the card and use the onboard graphics, system never hangs. whenever i reinstall the card. same thing happens.
