Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Yellow dosent work ok
I have a BZ 6500 but the yellow did'nt work before the machine give me code C2451 and C2411 and C-4520
I out the developer unit and replace developer again an dprint again but the yellow color dosent work in all area
  • Konica Minolta Master
  • 2,794 Answers
Theres a service code to run the calibration program to reset the colors. It should be ran by a technician because that machine is very picky about running the procedure the right way. If someone shortcuts it, it makes a big mess.
With three error codes on the screen, it won't be something easy on your end to clear it.
Posted on Aug 17, 2008
C2451
Posted on Sep 05, 2008
Konica minolta 6501 yellow pictures
Check the yellow drum and also check the yellow developing unit.
Aug 07, 2014 | Konica Minolta Bizhub C 6501 Color...
Yellow hues
Check the yellow drum and or the yellow developing unit
Canon e000020-01a0 is it alright to clear the error and work the machine
Yes, The error is a standard code for the drum/developer of a particular color. The 01 is for yellow, the A0 is indicating the measured value of the developer concentration is considerably low. This may be a reult of the drum unit going bad or serveral sensors going bad. How many copies does the yellow drum have on it? Warranty is for approximately 40,000 prints.
Aug 18, 2012 | Canon imageRUNNER C3200 Copier
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Ricoh 3228c error code 375 but only when i try to print color
Your yellow is the culprit. try reseating the yellow developer unit and or drum unit. if still codes replace the yellow developer unit.
Oct 17, 2009 | Ricoh Aficio AP3800C Laser Printer
What does error code SC387 mean on a dsc332 colour copier the machine giving off very bad fumes also
it means you have a calibration error in your yellow development. you probably need a new yellow dev unit or the clutch or gears that drive it are bad. it could be a bad motor also
Sep 23, 2009 | Gestetner Office Equipment & Supplies
Ricoh aficio cl7100 doesn't print yellow
does the demo page print ok?
try pushing the yellow developer unit in tight.
May 06, 2009 | Ricoh Aficio CL5000 Laser Printer
C-2451 on bizhub c450
C2451: New Transfer Cleaner Unit resetting failure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Nov 30, 2008 | Konica Minolta bizhub C250 All-In-One...
Yellow toner will not print
If you let the yellow toner get to the point where the toner cartridge was totally empty, there is one thing you can try which may help. From the "menu", select "maintenance", then go to "clean developer" and choose the yellow. The machine will then churn for a few minutes. What happens is there is a tube that moves the toner from the toner cartridge down to the developer unit ( which is behind the imaging drum). If the toner was allowed to totally run out, there is an area of the tube which may have little or no toner in it. Each time you print, there is a spring auger within the tube that draws the toner to the developer. By running the "clean Developer" it turns the auger and re primes the tube.
If this does not fix the issue, and you have replaced the imaging unit, then the yellow developer is defective and would need to be replaced. This involves quite a bit of work and is not considered user replaceable.
Aug 20, 2008 | Dell 5110cn Laser Printer
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Dec 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
387 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
