Can u Clarify what error your getting? or what you mean with Cannot Load Photomaker? Does it give a error or anything?Hi there,
You can't post conmments that contain an email address.
You might need upgraded version of photomaker software & it should be compatible to your windows.Download the latest version of photomaker and then install it.
you may be out of luck. A lot of manufacturers have a product life and once the product life is over they no longer offer support to the product. What this means is they do not make a driver if the product life is over and want consumers to buy a new product. However if you supply the model number and the maker of the scanner one of the many members of fix ya may be able to search for drivers and see if windows 8.1 is supported. I had a cannon LPB810 that went to the tip as I could not get drivers for it and I have a HP scanner with the same problem and it is collecting dust on the desk. I have to take it to the tip as well.
Hello
The CDs you inseting is not loading properly into the mechanism. Check its loading belt. If loading belt is loose, thie tyep of fault will occur. Check the loading motor also. If the pulling power of loading motor go less, the discs will not load properly and will ejected out as it loaded into. There is no other possiblilities other than this to check. OK.
The PhotoMaker model that you have is PC only. The manufacturer does not supply MAC drivers for this chipset unfortunately.
We're working on a MAC model, which will be available around April 2010.
You could also consider the PhotoMaker Pro which captures directly to an SD card. You then use your MAC to edit the photos.
Regards
Murray
Kaiser Baas
www.kaiserbaas.com
This error message is caused by having multiple scanner devices connected to the
PC which causes a communication error with Photo Impression and the PhotoMaker
device. Disconnect any scanner devices and all in one printer devices from the
PC and try again. Thanks
Hello. Go to your internet server. Delete all cache, history and cookies. Scan your computer for possible viruses. As there maybe an internet bug that is preventing the page not to load properly. And you can try it on another server like Google Chrome.
Hi amour459,
Have you found a solution to your problem?
I work at Kaiserbaas and hopefully can help you, alternatively, you can go onto support site http://kaiserbaas.helpserve.com/
Pam
