Question about Maytag PAV2300 Top Load Washer
PAV2360AWW SPINNING BUT LITTLE WATER GOING OUT
MY WASHING MACHINE IS SPINNING AND VERY LITTLE WATER GOING OUT THE PIPES AND A LOT MORE GOING OUT THROUGH THE BOTTOM. WAS TRYING TO TAKE THE FRONT OFF AND HAVING A REALLY HARD TIME GETTING IT OFF. HOW WOULD I GET IT OFF, PLEASE
  • 22 Answers
There are two spring clips on the left and right hand side where the front and top of machine meet they are located about two inchesin from both cornres best tool to use is butter knife .
push in on the clips while pulling up on the lid. when the top opens it will tilt to the back of machine.there are also two 5/16 screws that are holding the front panel to the cabinet also onthe left and right hand side!
Posted on Sep 07, 2008
My washing machine isnt loading with water
hi i think you mean a ball looks like a ping pong ball it doesent go in pump it sits in filter i allways take them out anyway its up to you strange about water check wires to valves were water pipes fit unplug 1st
Jan 12, 2014 | Hotpoint Aquarius WF210 Front Load Washer
Not spinning properly there is still a lot of water in clothes after spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Admiral Washing Machines
Spin cycle not working properly. A little water (1 inch) is left and clothes are heavy with water. I tried the spin cycle repeatedly - water still at bottom of tub.
heatman101
Aug 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Frontloader spins when washing but when it's time for the final spin it won't spin, even if I set it to the spin only setting and still nothing. What to do? Is there a belt or something?
heatman101
Sep 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
Water not pumping out, still spinning can't find blockage in pump or pipes
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Hoover Washing Machines
My washing machine isn't spinning clothes out all the way anymore... I have to run spin cycle twice to get water all out.
Hiya,
often when the machine needs to be put on spin twice to remove the water you will find the is an issue with the drainige, if the waist pip is pushed to far down the drainage or if you have lint build up it will greatly reduce the amount of water that can be released when spinning leaving it in your machine so i would surgest checking you drainage & pipes first to make sure they are clear enough for the water to escape
Hope this helps
Apr 23, 2010 | Maytag PAV2300 Top Load Washer
My washing machine is not spinning or draining but all else working
is the drain installed properly and is all the pipes clear if it is not this then it might be blocked or the pump is broken it is not spinning cus the water is in there it only spins if no water in there. hope this helps.
Sep 07, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My 2 year old machine does not fill, the spin cycle souds like it is spinning, but the drum stayes stationary. The adigator works
check make shore the water is not turned off at the back pipes , see if the belt is slipping , remove the top and put it on spin then look see if the belt on the moter is going round
Jun 24, 2009 | Washing Machines
Washing not spinning water out of clothes
Must be something in the pump obstructing the water flow.
Jun 14, 2009 | Washing Machines
Water continues to fill
you replace 'that'by turning off water going to 'it'remove top of machine,take off hose's on valve,fit them to new valve,with the wireing,do it step by step.buy,eire
Dec 11, 2007 | GE WDSR2080D Top Load Washer
Maytag PAV2300 Top Load Washer Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
