Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi projection tv
My tv turns off in a few seconds and I just got it today
  • 927 Answers
GOOD DAY; THE VS-45607 Model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. GOOD LUCK, big IRISH.
Posted on Sep 26, 2008
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Power on, few seconds off
Took it to the landfill today. Thanks for the reply!!!
Jan 25, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi tv model wd-62531 less than 2 years old
It sounds to me like your bulb has burned out. Look behind your TV for where the bulb housing is and pull the bulb out to check if it's burned out or not. You'll know when you look at it if it's toast.
Dec 10, 2008 | Mitsubishi WD-62531 Projection Television
MITSUBISHI BIG SCREEN TV
That sounds like the capacitor issue on the PWB PCB there is a kit for that available at the following link that includes all the capacitors and the borad location numbers of where they go, and it cost less than half what a repair tech would charge just to come look at it. Heres the link.
http://servicemanuals.vstore.ca/
Jun 22, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WS-55859 Won't Turn On
this is a job for experienced tech most of the problems are rela ted to convergence IC's in this case
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi TV 52'
Mitsubishi gives this error , when it does not detect a video signal.....Check your wiring.
Dec 24, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV WS-55511 Turns Off after Turning On
My mitsubishi big screen tv turns off in few seconds what should I do and I just got tv today please someone help
Oct 28, 2007 | Televison & Video
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Black square in middle of TV
Turn off the closed caption on the TV set. Someone has turned on that feature. Good Luck
Jul 12, 2007 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
110 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
