Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Riding down the freeway on my 1985 FXR, it was 115 degrees, bike stopped running. Have gas, don't have spark at plugs. New coil. New battery. New wires.
  • 216 Answers
Lotta possibilities....likely something vibrated loose. i'd start with something simple. after u check electrical connections and fuses,,,,, is the ignition module black lead secured to the frame ? all coil wires secure ? Pull the key ignition....check connections/ crossed? secure ?
Posted on Aug 17, 2008
SOURCE:
Have john deere lt190 after a few minutes running it shuts down. New fuel filter cleaned carburetor and gas tank changed oil. What else could it be??? Stumped
run it till it stops, have a spark plug ready to check for spark, if there is no spark, chances are the coil is bad
Sep 04, 2015 | John Deere Garden
Break light and turn signals don't work after a few minutes of riding
Hi Joe, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 31, 2013 | 2007 Harley Davidson FLHRC Road King...
I have replaced the battery and ignition unit on my 1985 suzuki 700 es, the bike really sounds like it wants to run but wont start. Starter turns but engine won't kick over. Any Ideas?
Is it getting gas properly? Has it been sitting around for a while? The carburators on motorcycles need to cleaned after sitting around. The jet could be full of varnish. Are you getting spark for sure? Pull out a spark plug and put it in the wire, crank it over and see if the spark plug sparks. When you pulled the plug was it wet at all with gas? Then it probably isn't getting gas right. Just some of the things you could try.
Feb 12, 2012 | 1985 Suzuki GS 700 ES
1987 Kawasaki ZL1000 quits running while riding
Hi, Jamescrosby6 and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, stator, magneto, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Faulty or corroded kill switch.
11. Accelerator pump damaged or not working.
12. Water or dirt in the fuel system, carburetor or filter.
13. Restricted, blocked or kinked fuel line.
14. Fuel tank empty.
15. The gas cap is not venting properly or fuel tank venting system blocked, loosen gas cap and go for a test ride.
16. A failed fuel pump, pressure regulator and or fuel injectors.
17. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
18. Needle and seat stuck closed in the float bowl.
19. Petcock clogged or damaged.
20. Lean angle switch is faulty or needs adjustment.
21. Catastrophic engine failure, perform a compression test.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike died while riding down highway Kawasaki Vulcan Forum Vulcan Forums
Help Bike dies while riding Ex 500 com The home of the Kawasaki EX500...
Kawasaki ZL900 ZL1000 Eliminator 1985 1986 1987 Service Manual Repair... $15
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
Aug 19, 2011 | kawasaki ZL 1000 A1 Eliminator Motorcycles
First of all, my bike is a 1999 Dyna Lowrider, with an 88 cube motor. I have roughly 80000 miles on it, and I've had the cams changed out to gears, and a bigger Screaming Eagle carb installed, all by a...
G'day, Maybe I can give you a few Ideas on how to start
.I'm thinking it may not be running on both cylinders properly and an easy way to check is to start the bike from cold(do this test in the first few seconds after starting from cold DON'T BURN YOURELF),put a bit of spit on your fingers and quickly touch each exhaust header in turn, to see that they are all warming up equally together.This will narrow down if your problem is related to one cylinder.
If one pipes is cold/er than the other then you know which cylinder is causing the problem.
If you find that this is the case- one of the headers are cold then.
Remove the spark plugs-Keep in order.Examine the plugs-used plugs tell a story.How do they look?clean?black & sooty?Are they the same colour?
Re-fit plugs to caps,sit plugs on metal of cylinder head,press starter - cheack for spark on both plugs.DO NOT HOLD OR TOUCH PLUG/CAPS WHILST CRANKING-WARNING - HIGH VOLTAGE- CAN KILL.
I can also suggest a few common problem that bothered most Harleys'.
They were notorious for open circuiting their spark plug caps on either cylinder.Having the coils tested will confirm this. If you have a multi meter let me know & i'll guide you through testing them.
If you leave the ignition on & kill switch on on a Harley, they cook the coils- quite common.
I hope this helps you to narrow down your problem.
If not let me know & I'll try & help further.
Kind regards Andrew Porrelli
May 11, 2011 | Harley Davidson FXDWG Dyna Wide Glide...
1983 yamaha venture royale 1200--- no power on high end. runs great at idle and going thru the gears up to 50mph then sluggish after that. changed the air filter, gas filter, plugs and brand new non...
good maintnance what you did. but these bikes lacked power in high gear and I used to always have to gear down and pick up more spead. remember that they are a touring bike so you shouldn't even be in 5th at 50mph. try this build enough speed and stay in 4th and don't go up to 5th unless you hit at least 60mph or a bit more. I have an 04 now and guess what, they are all the same you gotta build enough speed before 5th, I toped the 110mph on mine just last week. moral of story, don't treat them like normal cruisers, stay in 3d gear when around town. 4th is just as you get on the freeway and 5th is only for freeway.
I hope this helps.
Apr 29, 2011 | Yamaha Royal Star Venture Motorcycles
1986 VF500F Honda Interceptor Just bought the bike today. The guy we bought it off of said it needed new spark plug wires. He gave us the wires and also the coils. My husband replaced the spark plugs,...
Any idea how long the bike sat without running? So assuming spark plugs weren't wet, it's likely not getting fuel. If it hasn't run for a year or so, you'll have to empty the fuel tank and drain the carbs. Try fresh gas and new spark plugs. Make sure the fuel tap is on and fuel is flowing into the carbs. Also be sure your choke is closing when you move the lever. Check to be certain kill switch is in the run position. Charge battery so you have good cranking power.
May 21, 2010 | Honda VF 500 F Motorcycles
Motorcycle no start condition
first things first change the spark plugs and then make sure ya have fresh gas it as well.
May 11, 2010 | 1993 Harley Davidson FXR Super Glide
My bike turns but dosent get the spark to fire up
Quite often I've found on older bikes the coil can become corroded.  I would begin by taking apart all the electrical connections between the battery, ground, the plugs themselves, the coil, and the generator, and giving them a good clean.  Most of the time I've found, that should eliminate your problem.  A good way to troubleshoot this is to jumpstart the bike.  If the bike will start (i.e. has spark) while jumped, but will not run when you disconnect the jumper cables, it is most likely a corrosion problem somewhere in your system.
Good luck with your bike!
May 26, 2009 | 1985 Yamaha XJ 700 X Maxim
Lands Phones Logo
193 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
