Re: My O S is windows 7 , lipi printer 6306L is not...
Unfortunately lipi printer 6306L is not compatible with windows 7. There is no driver that would apply for windows 7. For more information you can check this link; http://www.lipidata.com/Drivers/index.htm.
If the OEM is not making a driver then your probably out of luck. You may have to go back down to Win XP or sell or return the item. Not all manufactures have caught up with Win 7 drivers so you need to make sure there is a driver for the equipment you purchase.
if your printer is compatible with the Os like XP ME then please switch to those OS.Using those may be easier than windows 7. try thins this is the only think you can do instead of waiting for HP to do something.
I'm sorry, but the Lexmark 2350 is not compatible with Windows 7.
I checked some driver links, it Lexmark released some drivers for the supported operating systems like: Windows 2000/2003, Win XP, and Win Vista 32-bit and 64-bit OS.
If Windows 7 is supported, Lexmark will surely release a driver for this OS.
platen calibration has to be done . in offline press lf and enter for tech access on , then go to test menu, select diag,then select call engine , then select platen cal and press enter , it will ask remove ribbon and remove paper , then it will automatically calibrate . then ur problem will be sloved
Canon i850 will only work with a Win 7 computer that already has the XP driver on it (upgraded from XP). The so-called Win 7 driver is actually an "add-on" for the original driver which cannot be installed on a X64 Win 7 computer. Catch-22........gotcha!!!!!
