Question about Kodak EASYSHARE 5100 All-In-One Printer
Printing problems My pictures are printing out with lines going through them. You can hear the printer is not printing right because you can hear it stop and go etc. Thus the lines.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Right..try a head cleaning and alignment procedure
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
Not printing properly
Print heads need to be cleaned cause they are clogged which is why even replacing the cartridges is not fixing the problem.
If the printhead can't be cleaned then a new printer is in order.
Apr 19, 2010 | Kodak ESP 5 Printer
When trying to scan or reprint a picture on my HP photosmart C5180, and I choose a 4x6 or 5x7 or8x10, it prints out a thumbnail picture. If I insert my card from my camera, it prints a beautiful 4x6 print....
please go ahead and right click on the printer icon and ytou will get an option that says printing preferences
fromthe printing prefercnces select photo printing select the right photo printing
select the size and the printing type
hope this should fix the problem for more details you can also foillow the instructions from hp
since the ocpy is not fine you can try and do these steps:
1.disconnect the power cable from the back of the printer
2.press and hold the power button of the printer for 20-30 seconds
3.restart the printer and see if it coipies fine
for more details please download the manual from te following URL ;
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=1153481&lc=en&cc=us&dlc=en&lang=en&cc=us
thanks
regards
Hamid
Feb 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
It will print text but pictures are not printing properly, the pictures have lines and colour is not right
First check cleaning the printing head, if not helps change the cartridge and try print....
Good Luck
Nov 23, 2009 | Epson Stylus D88 InkJet Photo Printer
I keep getting the message that my canon mp360 is off-line when I attempt to print.
This could be a couple of things but this is the quickest easiest fix so we will try this first go to start then go to your control panel go to printers and faxes once there you should see your printer name right click on it and make sure that it says use printer offline in the drop down menu if it says use printer online left click on use printer online and that will most likely fix your problem if you have done this step and still having problems turn your volume up a little unplug your printers usb cable you should hear some dings if not its ok now Plug your USB back into your computer wait a couple of seconds you should hear some dings try printing something se if it works (you may or may not hear dings depending on your volume settings) if it's not printing or dinging take the usb plug back out the back of your computer and try another usb port if you still hear no dings and it's still not printing switch usb cords it is likely that the cord is bad
Nov 21, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
How do I get rid of the lines in my printing of pictures
1st try to clean and or align your cartriages. sencond right b4 you print you know right before you press ok go to setting and make sure you choose photo quality and make sure you chose best photo also check that the printer aint printing on high speed search through all the tabs. contact me if you need further help
Aug 11, 2009 | Dell 948 All-In-One InkJet Printer
The color is not adjusted right.
The first step is to determine whether the problem is in the printer or the driver.
Run an alignment test and then, using the printer menu, print a picture that is within the printer.
If the internal picture has the same problem, and all ink cartridges are flowing properly (you will be able to tell from the alignment test), printer replacement is going to be the least expensive repair.
If the internal picture prints ok, then try printing a picture from the computer again. If that gives you the old problem, disconnect the printer from the computer. Then, uninstall the printer, reboot twice and reinstall the driver, hooking up the printer when asked.
Jul 28, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
Canon Lines in picture and colored word doc
you should check whether the color ink is out or not. If so replace it with a new one. Otherwise just cleaning the print head will solve your problem. To clean the head Go to control panel > open printers and faxes > right click printer icon > Click properties > Find the option "Clean print head" or somthing sismilar. Use it and your problem could be solved. Note: Some printers have seperate software utilities to clean the print head.
Sep 11, 2007 | Canon Pixma iP6600D InkJet Photo Printer
My printer makes lines through all the pictures i try to print
I had same prob with Epson but went into preferences/main and changed from text and graphics clicked to picture or best picture..problem solved.
Aug 26, 2006 | Canon PIXMA MP130 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
