Question about Insignia NS- 27" TV27 TV
Insignia TV my insignia tv keeps turning itself on and off. when you plug it into the wall there is a little green light that comes on and a few seconds later it goes off and there is a white line in the middle of the screen that obviously tells you that the tv has shut itself off... this continues until you unplug the tv. any help would greatly be appreciated.
  • gmoney461 May 05, 2009
    i have the same problam, the tv in on then i turn it off and it turns back on right away, so i turn it off again then pops back on. and my dvd/vcr in one will not show picture only sound. everything is plugged in perfectly...i dont understand this.....this tv is garbage!
Ok, I had the exact same problem last summer, and Kevellen told me of a problem that Insignia tv's have: the circuit that controls whether the tv is off or on is messed up, and it can be fixed, but its not cheap.
http://www.fixya.com/support/t924975-wierdness_tv
Anyway, if the t.v. is still under warranty, I would say return it to the store and see if you cant get a new one, and from what I researched online after this incident, I will not buy an Insignia aver again.
hope this helps,
-Steve
Posted on Jan 04, 2009
My insignia tv turn on when it want to.push button to turn on ,button light come on ,no tv later it will come on.
Posted on Sep 02, 2010
My insignia tv keeps turning on and off by itself. is there a way to reset the set?
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 13, 2014 | Insignia NS-LCD19 19 in. LCD TV
Why a 19' Insignia TV wont turn on?
Verify you have power at the outlet, and the TV plug. If no power check breaker. If it was moved recently to anoither location the wall outlet may be on a switched circuit, or downstream of a GFCI outlet.
Aug 20, 2014 | Insignia NS-LCD19 19 in. LCD TV
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
Have an insignia tv that won't power on...was off..made popping noise...won't power on. checked power in both the surge protector it was in & wall. all other items plugged into surge protector work....
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Insignia NS-LTDVD19-09 LCD TV
Insignia LCD TV 32 inch will not come on
I received no replies to my request. I guest I stumped 2 million techs. I'll just buy a new TV with a 5 yr warranty. No thanks to joining your service, I can do bad all by myself.
Feb 08, 2010 | Insignia IS-LCDTV32 32 in. Television
I have a Insignia 19in. We turn it on green light flashes then tv turns off. It comes back on stays on for a few then off again. Got picture sound and everything.It will not stay on or off just keeps...
Try power-cycling (turn it off and unplug for several minutes) and restoring the TV to factory defaults. Also, to ensure that the remote isn't causing the problem, remove its batteries and press all of the buttons before installing a fresh set. If these steps don't correct the problem, repairs may be required. Service can be obtained by carrying the unit in to the place of purchase.
Jan 08, 2010 | Insignia IS-LCDTV32 32 in. Television
Insignia? 37 720p Flat Panel LCD HDTV will not
Power-cycle the unit (turn it off and unplug for several minutes). If you're unable to power the unit on successfully, the TV probably requires repairs. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 03, 2010 | Insignia 37" LCD Flat-Panel HDTV
Insignia flatscreen won't turn on
Your TV should be repairable. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Dec 24, 2009 | Insignia IS-LCDTV32 32 in. Television
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Insignia NS- 27" TV27 TV Logo
2,074 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
