Question about Singer 7436 - INGENUITY
Winding bobbin thread
Hi. I have a Singer Ingenuity 7436...brand new
I have threaded them machine according to manual, and the bobbin will not spin to put the thread on
step 4 says Start machine... ??
does that mean press peddle, cause the needle then tries to sew the bobbin sits there ... I dont get it...
I have had a machine for ever, and finally got a new one... I cant figure out how to load the thread on the bobbin
thanks Kathy
Did you move it to the right?It has to be against the piece above the wheel.
Posted on Dec 10, 2008
I cant get my needle to go up and down on my singer ingenuity 7436 even if I do it manually it seems to get real tight and stop
Possible thread is wrapped somewhere in the mechanism preventing the machine from moving freely.
Oct 08, 2016 | Singer 7436 - INGENUITY
How to adjust the bobbin assembly for singer 7436
How do you want to adjust it? Is the bobbin thread too loose or too tight?
Jun 23, 2014 | Singer 7436 - INGENUITY
Singer ingenuity 7436 manual free
Sounds like you didn't thread your Bobbin correctly
Dec 15, 2013 | Singer Sewing Machines
Singer ingenuity, i get error 88 when i try to wind bobbin. what am i doing wrong
On some of the singer machines that error means that the bobbin is in the wind position ,., I would chechk the bobbin and make sure it is in the propper position and switches like it is supposed to ..
Jun 02, 2010 | Singer 7436 - INGENUITY
Top thread does not engage bobbin thread
Check the needle to be sure it is not bent or mis-installed. The flat side of the needle shank faces to the back to the machine.
If this does not work, open the manual and wind and install the bobbin, then thread the machine - using the written instructions as the pictures, although helpful, can mislead.
Continue by lowering and raising the threaded needle (hold on to the end of the thread) to bring up the bobbin thread.
Pull both threads under the presser foot and to the back of the machine.
Hold onto the threads and lower the needle into the fabric and then use the power pedal to begin sewing.
If the top and bottom thread still do not form a stitch, the machine needs to go into the shop for service as the alignment needs to be adjusted.
Mar 11, 2010 | Singer 7436 - INGENUITY
Using Singer 7470 for the first time, and my bobbin thread is bunching terribly. There is a loud sound from the bobbin chamber, as if the mechanism is bouncing around??? How can I fix this bobbin issue?...
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Chickiefl
Apr 15, 2009 | Singer 7436 - INGENUITY
Singer 7442 Bobbin Will not wind
to wind a bobbin you get thread and put it where it usually would be put it behind those 2 metal piece (see pic in manual) and there put it around the thread guide and then u put the tip of the thread through the hole of the top of the bobbin from the inside to the outside  and u are really to start, u should already have the bobbin and the spinning metal piece, then u move the metal piece to the right into the notch and press the presser foot and hold it until it stops you and you're done :-)
Mar 24, 2008 | Singer 7436 - INGENUITY
Singer 7436 - INGENUITY Logo
278 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
