Question about Star Logic Computers & Internet
Star Logic 20.1 Monitor
I need a new power supply for my Monitor. Where do I find one?
  • Star Logic Master
  • 5,568 Answers
You may need to first find who made it.
If you can find a sticker with an 'FCC ID' number they might be listed with the FCC by manufacturer's name.
You can decode it here if present:
Posted on Aug 17, 2008
Model M17ANA shuts off intermediatly Turns on ok but after a few seconds shuts off then back on again.
The issue you describe is a power supply gone bad. Actually it is a capacitor inside the PS that is now defective (it may be more than one). This seems to be a frequent problem with this particular monitor as I have personally had the same issue with one a owned.
Unfortunatly there is no good solution as there are basically only two options available to you.
1. Find an 'electronics /computer shop' that will remove the PS and repair it.
2. send the monitor to Star-Logic for repair.
The basic issue with either scenario is that the cost to repair may be more than the unit is actually worth. For instanse, you can purchase a new 20" LCD monitor for less than $90 form places like
I hope this helps you in some way.
Good Luck!
Oct 20, 2011 | Star Logic 17" LCD Monitor
I need a replaqcement trqansformer for my Starlogic monitor model # HD20W) the transformer is 120V -!2v 5A. Thanks for youyu help.
If the transformer puts out a simple 12 Volts regulated at 5 Amps, you should be able to go to any electronics parts distributor and order a regulated power supply at the mentioned specs. There are models that come enclosed with terminals on them. You can also buy the supply raw, wire the AC cord to it, get an enclosure for it, and wire the the 12 Volt output side to the TV as necessary.
If you are not experienced at doing this type of work, find an electronics type person to do this for you. If you confuse the polarity to the TV set, or not select the proper power supply, you can damage the TV set.
These power supplies are not very expensive. A new low cost one can cost about $60 to $80 US depending on the model type and rating. Professional high quality type supplies can cost a lot more.
Sometimes these supplies can be found slightly cheaper from electronics parts surplus dealers. I have seen them sold surplus for under $20.
Jerry G.
Oct 15, 2011 | Star Logic 17" LCD Monitor
Monitor wont start up, keeps shutting down
You probably have a busted power supply in the monitor (usually as expencive to fix as a new monitor)...
Sep 01, 2011 | Star Logic 17" LCD Monitor
I need a new transformer/plug for my starlogic monitor. where can i find one?
Do you need the complete power supply or just the power cord?
Try any local computer source... Best Buy, Radio Shack etc.
Nov 27, 2009 | Star Logic 17" LCD Monitor
I have a Star Logic 20" monitor and cannot get the resolution set higher than 800 x 600. HELP?
You are limited to the capabilities of your video card in your computer. The monitor itself is not part of the ability to raise the resolution. Go to Display Properties under Control Panel and slide the resolution all the way to the right. If the max is 800X600 then that is the max for your video card. Buy new video card.
Rate the solution with 4 diamonds.
Mar 02, 2009 | Star Logic 17" LCD Monitor
Star logic monitor settings
I typically do capacitor replacement on lcds all the time insde, the board for power will most likely have 1 - 4 blown capacitors, replace these and the monitor should be good as new, btw 1 is a 10 v smallish size you can replace it with a 16 volt same MF.
Sep 10, 2008 | Star Logic 17" LCD Monitor
Star logic 19" lcd monitor
This is most often caused by a serious failure and the power supply is protecting itself and you from fire by cycling the AC off and on.
Aug 08, 2008 | Star Logic 17" LCD Monitor
Star logic 19inch computer monitor power adapter STD-1205
You can use a power supply for a CCTV system. Here is a website that has one, it is for a DVR4220, code STD-1205
Jul 27, 2008 | Star Logic 17" LCD Monitor
Where can i purchase another power cord for my monitor
starlogi typically use a standard computer power supply cable you may find one at any computer service center commercial or mom and pop
Jul 13, 2008 | Star Logic 17" LCD Monitor
Computers & Internet Logo
73 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
