2005 Cad STS with Bose system
We have only fair FM signal in our area. How do I shut off the ST, stereo function, on the radio to improve the reception. When the ST in trying to play I get static / bad reception when the FM is weak.
FM radio settings Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source. FM stereo option You can choose between stereo or mono reception when listening to FM radio. Mono may improve clarity where stereo signals are weak. To change between Stereo or Mono reception: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Audio Setting’. 3. Select between ‘Stereo Allowed’ or ‘Forced Mono’. FM scan You can choose whether your Elan E3 automatically stops at the next available FM station or the next available FM station with a strong signal when scanning for an FM station. To change the FM scan setting: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Scan Setting’. 3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source. Full scan You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and remove inactive ones. To carry out an autotune: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be displayed during the autotune. When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the last station you were listening to is no longer available, your Elan E3 will tune into the first station in the alphabetical list. Manual tuning To manually check the signal strength of a known channel: 1. Press the Menu button. 2. Turn and press the Select dial to choose ‘Manual tune’. 3. Turn and press the Select dial to choose the channels.
eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
You can buy an AC line conditioner, they range from cheap and useless to expensive and exotic, which is able to filter interference coming over the power lines. Simply plug that into the wall, and your radio into the filter, and there should be an improvement.
You can also try plugging the radio into a different outlet, making sure the outlets are wired properly, and try moving the radio to a new location further away from the source(s) of interference.
The Bose uses its power cord as an antenna. The cord has to be stretched out (not coiled) to pick up stations. It also helps if it's oriented the right way -- try changing the direction (having the cord running east to west, say, instead of north to south). Moving the radio and the power cord closer to a window can help, too, especially in a commercial building. These structures often have a steel frame which can block radio signals. If all the above fail, your best bet is to buy an indoor FM antenna, which can be as simple as a piece of wire made into a dipole antenna or as fancy as one of the Terk mini-towers with built-in amp. Bose sells one for their radio, though it's kind of expensive for a simple length of wire. You can get the same thing from Radio Shack, but if you do, be sure to pick up their adapter (catalog 278-257) to plug it into the non-standard Bose jack. All together you'll spend half what Bose wants. Move it around like you did the power cord and you should see a big improvement.
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
The only thing you can do is pull the radio and have it repaired, cost is about $150-$250 USD Many website's offer the service and instructions on removing the radio for free. Below are some of the websites
2005 STS4 In the center console there are audio video jacks. Go to radio shack and grab a cable with audio/video one side headphone the other. Plug into your iPod and put the touchscreen setting on AUX. It's on the screen getting to bluetooth
