Posted on May 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Couldn't send fax. no tapi device found
Victorman
Level 3:
  • Office Equip... Master 846 Answers
  • Posted on May 30, 2011
Victorman
Level 3:
Answers
846
Questions
0
Helped
309095
Points
2441
I presume you are trying to send a fax from your pc?
Most modern pc's do not have an internal modem. Check to see if you have one and if so that it configured for the correct type of dialling ie tone or pulse.
Our fax machine is not sending faxes. Message saying 'Storing Fax' job added. Not Sending. Please help. Thanks so much
you must resset ur fax machine at ur connected device ,or via computer , ur fax machine is giving u problems becz of some propertise built in had changed, so resset is best option
Kendala tidak bisa menerima fax
Saya memiliki mesin FAX merk Panasonic KX-FT 987, kalau dari lokal bisa menerima file FAX, tapi kalau dari luar negeri tidak bisa, mohon solusinya gan!!!
1helpful
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
How to send multi recepient
Given the model of the printer you indicated, I assume your use of the word "send" is in reference to the fax function. Sending a fax to multiple recipients is actually quite easy! Here's how you do it:
1. Load your document into the ADF (automatic document feeder)
2. Dial the fax number of your first recipient
3. Press the button with the check mark on it (DO NOT PRESS SEND AT THIS POINT)
4. Dial the number of your next recipient
5. Repeat steps 3 through 4 until you've entered all the numbers you intend to send the fax to
6. Once all numbers are entered, press SEND
That's all there is to it! If you found this solution helpful, please leave a positive rating!
I couldn't find Singapore airlines email address
Please read the following, it could be useful:
City Office
Address
Singapore Airlines
Passeig de Gràcia 50
2nd Floor Unit 2a
Barcelona 08007
Spain
OCS Mail Stop: BCN TWN 02A
Phone 902 380 777 (Reservations - within Spain)
+34 934 873 908 (International)
Fax +34 934 872 733
Email [email protected]
Airport
Address
Singapore Airlines Ltd.
Aeropuerto de Barcelona
Terminal 1, Dique Sur, P10, Zona S,
Oficinas 70-73,
08820 El Prat de Llobregat,
Barcelona,
Spain
Phone +34 932 971 308
Fax +34 932 971 310
Baggage Office
Address
Flightcare
Lost and Found Department
Arrival Hall Terminal A
Barcelona Airport
Phone +34 932971076
Telex BCNLL8X
BCNKKSQ
Call Centre 24/7 (Singapore)
Phone +65 6223 8888
Fax +65 6786 6947
I need to know how to fax a doc
Open the document.
Click File
Click Printer Setup
Select the 'fax' device, instead of your "default" printer.
Click File
Click Print
A windows will open, asking you for the FAX-number of the destination FAX-machine.
Enter the telephone-number.
Click OK, to send the FAX.
I have recently purchased 4 Gigaset AL140's which are all registered to the same base, and found that, every now & then when someone calls, there's what sounds like a fax tone in the background. No -...
The sound you are hearing is radio interference, which is stated in the manual and on the base itself as having to be accepted. There are a couple of steps you can take to prevent this:
Move the base to a location away from other radio devices, including but not limited to: Microwaves, computers, dvd/cd/audio players, other phones, radio's, basically anything electronic that sends out a signal.
Moreso, cordless phone's generally have a feature allowing you to change the channel that they send/recieve signals on. Changing this may have a better effect on sound quality. The instructions on how to do so are in your manual!
Good luck
Can't receive faxes
Check to be sure your modem drivers are installed properly, or they are the correct version for your modem. You may need to re-install the drivers.
If the device still does not function correctly, you may need to purchase a new modem, they usually aren't very expensive.
Fax problem
Hi Fatimo25,
The screen on your fax machine displays how the machine is set to receive calls. TEL MODE means the machine will not auto-answer incomming calls and will operate as a normal telephone device, it will still however be able to send a fax in this setting.
Place your message on the original tray and pick up the handset, dial the number and when the distant machine answers press the start key or ask for their fax machine and when you hear the high pitched fax tone press start.
There is a button on the panel that will allow you to change the reception mode of your machine to the other settings.
Your machine is of a model that doesn't come into this country so I have no manuals to forward you. You can try however to access the SHARP web site www.sharp.ae
Hope this helps you
regards
Gavin
1helpful
2answers
Fax machine error
HI,my fax machine couldn't send and receive messages.it shows me an error code that read as 0552H call service....what does it mean..? please help me.
k24674
ADMIN Andrew
ADMIN Andrew
